Question about RELIANCE ELECTRIC WATER HEATER
Electric 40 gal red reset button keeps tripping
  • 20 Answers
You need to check your heating elements. also check for any loose wires as you may have a fire hazard as well.
Posted on Sep 16, 2010
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 22, 2012 | Water Heaters
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
Red reset button keeps popping on 50 gal elec. water heater
Check the wiring to each element for burn ends that indicate a short, And more than likely it would be best to replace the thermostat to be on the safe side. It tripping off for a reason, you may reset it several times and eventually have to replace it.
Nov 04, 2011 | Reliance & 50gal Electric Water Heater
No hot water Unit has power Thermostat is set at 125 degrees.
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for Electric Hot Water Heater
heatman101
Jul 09, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 26, 2011 | Rheem MR105245 Marathon Electric Water...
Elctrical wiring of the thermostat Rheem hot water system
heatman101
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
Nov 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Keeps triping red reset button 640 dors
More than likely it needs to be replaced if you have to constantly reset it. Shut of power and repalce thermostat, it just snaps in place and easy to remove.
Sep 02, 2010 | Reliance & 40 Gal Electric Mobile Home...
Can this water heater be reset
Red button on upper thermostat just press it to reset.
Jun 07, 2010 | Reliance & 40 Gal Electric Mobile Home...
RELIANCE ELECTRIC WATER HEATER Logo
99 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
