Question about Dishwashers
Hello, I have a CONSTRUCTA S9W1C dishwasher with aquastop. Unfortunately, I tried once to start it with the house water supply closed. Of course it stopped after a few seconds. After that time, when I start it, the water pumps works and after some seconds the cycle stops. It gets no water. I've checked and noticed that no water passes through the aquastop valve. The aqua stop has two wires that get into the dishwasher. Do you have any suggestions? Thank you for your time Alex
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 1073 Answers
have they checked the thernals on the bottom of the tub
Posted on Apr 12, 2008
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
SOURCE: Dishwasher Bosch SRV3303 can't fill the water
Aquastop valve was damaged. Nominal resistance is 2000 (4000) Ohm depends on variant.
Posted on Aug 25, 2009
SOURCE: My Bosch integrated Dishwasher SGV5303 has stopped filling with water. An Aquastop unit is fitted but the filter in that is not dirty/blocked. Any ideas? Regards, Bob
The same thing happened to mine in March 2010
Posted on Apr 06, 2010
Fisher and paykel error code 6 on dishwasher
The code E6 is for the flood switch
Pull the appliance out, tip it back about 45 degrees and see if water runs out of the base.
If it does, drain the base (under where the tub) completely and the anti flood should reset.
If there is an aquastop device on your fill hose, after draining the base, turn off the water supply, disconnect the aquastop device and allow it to de-pressurize. Connect it back up and try again.
If it happens again, you'll need to check for a leak.
The normal cause is over foaming, using multifunction tablets and rinse aid, or just spilling rinse aid.
Dec 28, 2016 | Fisher and Paykel Dishwashers
My miele dishwasher keeps taking water as soon as I close front door (even when program has not been started yet) after while it displays F18 fault and starts draining
Find out what the error code F18 represents. Owner's manual troubleshooting section is a good place to look or search for it on the internet.
Mar 07, 2016 | Miele Dishwashers
Siemens Dishwasher flooded. Now it doesn't take in any water and does not finish program. Aquastop filter?
Typically all dishwashers have a maximum full switch that is located on the bottom of the inside of the washer, on some it looks like a round plastic cap about two to three inches round, if you grab it it will move up and down as much as a half inch, this is a float that when the water level is at the maximum will turn off the water inlet solenoid, I have had something small (in my case a small lid) get under this float holding it in the up position so it would not allow the washer to fill with water, after removing the lid the float went back to the correct position and everything worked fine. I would say this is happening to you by what you say has happened.
Nov 12, 2013 | Siemens Dishwashers
How to use the dish washing machine 'Constructa'
open the door and put all the way to ur left inside the dishwasher and close the door start your washer
Feb 21, 2013 | Washing Machines
My SE53200GB/01 fails to input water. I have checked the inlet supply hoses and filters and they are clear. I have tried different programmes and they all activate but the water fails to enter the main...
Your aquastop system is activated :deactivate by turning off the water supply, running the dishwasher so that it is expecting to fill (if you hold the grey square box at this point, you should feel it slightly vibrating, which is a good sign that it is working ok). Clear the filter in the aquastop. Turn off dishwasher via the reset as per model. Refit valve, turn on supply and check for water tightness. Finally, restart the the d/w and if there was a fauklt with the aquastop ( and not a different fill problem) this process should have reset it. Hope this helps.
Dec 08, 2010 | Siemens Dishwashers
Water supply to my Bosch SHE43CO5UC/17 dishwasher seems interrupted and not being supplied to the unit. Water supply to the unit is checked and confirmed available. What are the possible causes, i.e. stuck...
Could be a dirty hose filter or faulty inlet valve. Ther could be a leak and the bottom of the unit has flooded activating the flood safety which will cut the water supply. The pressure chamber and/or the hose pressure chamber to sumo could be block (take of left side panel and these are at the bottom right). Finally, the aquastop (grey box connected to the mains water supply that feeds the d/w) could be activated, faulty or fitted in the wrong position
Hope this gives you some where to start..
Jul 07, 2010 | Bosch Dishwashers
When starting wash cycle the dishwasher cda cw447 doesnt appear to be getting enough water in and is making a droning / whirring / electrical ? noise. pipes all connected ok inc aquastop water supply unit,...
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from www.espares.co.uk, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Sep 12, 2009 | Dishwashers
Aug 25, 2009 | Bosch SRV53C03UC Built-in Dishwasher
Meiko dv80.2 error 201
Error code 201 Indicates the incorrect water level...in that the level was not achieved during filling...check the following.
Correct water level was not reached during initial filling.
Check that the water hose is correctly attached and is free of “kinks” or pinching. Also check that the water supply is turned on.
I hope this helps...thanks for rating my effort....the Fang
Jan 30, 2009 | Meiko DV 80.2 Dishwasher
Dishwashers Logo
170 people viewed this question
Top Dishwashers Experts
