Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
What is torque for polaris 2002 indy 500 carb boots? where it bolts to cylinder head. they are 6mm bolts
    Sergeant:
  • 192 Answers
There isn't a specific torque that I'm aware of. Just tight.
Posted on Sep 11, 2010
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
I have a 2000 polaris indy 500, seems to lack power and when you let off after giving it alot of gas and then give it gas again it backfires thru the carbs. it really lacks power...
I WOULD DO I COMPRESSION CHECK ON THE CYLINDERS, THEY SHOULD BE SOMEWHERE AROUND 100-130 PSI WITH A DIFFERENCE OF NO MORE THAN 15% BETWEEN CYLINDERS
Dec 12, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500 efi snowmobile and I just put a new piston cylinder head on it and got ot to run but however it will run and take off accept when the throttle is wide open it dies and I have...
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
2000 indy 500 only runs on choke at times, some times it runs fine
check the carbs. It could be they need to be cleaned. To do this pull them off and flip upside down pull small philips head screw then big center bolt....set carb bowl aside then with very small screw driver pull jets and check for blockage. You should see light through these if not carefully blow through them and recheck. make sure you clean them all This should be done every year and can cause engine to lean out and blow up.
Jan 10, 2010 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
What is the head bolt torque on a 1990 suzuki lt250r quadracer changing head gasket had head resurfaced need to know the proper torque thank you just put in rm 250 no category for atv
The 8mm head bolts are torqued at 19 - 21 ft/lbs.
any smaller 6mm bolts are torqued to only 6 ft/lbs
like those on the lower cylinder.
Aug 20, 2009 | 2003 Suzuki RM 250
Torque setting
Ok, lets see- I still have my old official shop manual for that bike...Cylinder head nut torque is 16-20 ft lbs,Cam sprocket bolt torque is 12-17 ft lbs, Valve adjuster cover torque is 7-10 ft lbs, Cyl head cover torque is (6mm)- 7-10 ft lbs (7mm) 9-12ft lbs, Rocker arm adjuster nut torque is 11-13 ft lbs.
Nov 20, 2008 | 1984 Honda FT 500
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
165 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
