Question about Mtd Garden
How do I replace spring extension-part # 732-04076A. what does the spring attach to?
Dyson DC25 -wand extension lost a spring and becomes disconnected during use. I don't know where spring should be?
The button you push to release the wand has a spring to allow it to spring back after the button has been released. If that spring is missing the wand will not stay attached.
Jan 10, 2017 | Dyson Vacuums
Change springs on garage door
It's is straight forward. Select a replacement spring with the same tension color as the original spring. The color is applied to one of the hooks. Above all thread the safety wire through the center of the spring.
Feb 02, 2014 | Stanley Hardware 730610 110 Lb Garage Door...
WALK BEHIND SELF PROPELLED MODLE NO. CC997ES.THE DRIVE CONTROL IS SET AT #1. IT TRAVELS TOO FAST. WHEN I RELEASE THE DRIVE LEVER, SOMETIMES IT CONTINUES TO MOVE FORWARD.\r\nDIFFICULT TO BACK UP, REAR...
I have the same issue. Just tore into it and found the return spring on the transmission idler pulley is broken. Without the spring the idler pulley arm keeps the belt engaged and wheels turning. The spring is attached to the idler arm just below the belt pulley. Looks like the trans has to come out to get to the spring. I just found the P/N for the spring. MTD 932-0849A (replaces 732-0849A) Extension Spring. Your price: $2.62
Jun 27, 2011 | Sears Saws
How do you remove the manual shift lever from a 1994 acura legend
YOU HAVE TO UNSCREW THE SHIFT LEVER KNOB. REMOVE THE CENTER CONSOLE.REMOVE THE RUBBER SHIFT LEVER BOOT AND THE DUST SEAL.YOU NEED TO RAISE SUPPORT VECHICLE ON JACKSTANDS ON LEVEL SOLID GROUND.YOU HAVE TO DISCONNECT THE EXTENSION ROD FROM THE TRANSAXLE.SIMPLY REMOVE THE BOLT THAT ATTACHES IT TO THE EXTENSION BRACKET.TO DISCONNECT THE SHIFT ROD FROM THE TRANSAXLE PUSH THE DUST BOOT FORWARD REMOVE THE CLIP AND DRIVE OUT THE SPRING PIN WITH A PIN PUNCH.DISCARD THE SPRING PIN.DO NOT REUSE IT.TO DISCONNECT THE REAR END OF THE SHIFT ROD FROM THE SHIFT LEVER REMOVE THE NUTS AND BOLTS.THEN REMOVE THE TWO NUTS AND WASHERS THAT RETAIN THE CHANGE BALL HOLDER TO THE UNDERSIDE OF THE EXTENSION ROD AND REMOVE THE CHANGE BALL HOLDER LOWER THE SHIFT LEVER DUST SEAL,SHIFT LEVER BALL SEAT,SHIFT LEVER AND EXTENSION ROD.INSPECT THE BUSHING AT THE FRONT END OF THE EXTENSION ROD AND REPLACE IT IF ITS CRACKED TORN OR WORN. REPLACE THE ORINGS IN THE BASE OF THE LEVER.BESURE TO LUBRICATE NEW O RINGS AND BUSHINGS WITH A SILICONE GREASE.USE A NEW SPRING PIN TO ATTACH THE SHIFT ROD TO THE TRANSAXLE.INSTALL EVERY THING BACK VISA VERSA.
Mar 02, 2011 | 1994 Acura Legend
Garage door does not open. goes up about 4 inches. disconnected from opener and still can't open. checked wheels in frame move by hand. opener works when not attached to door.
You probably have a broken torsion spring. If you have a spring on a shaft above the door (usually 2 if it is a double door) then you have a torsion spring. From this shaft you have a 2 cables wound on a drum going down to the bottom of the door. If it is a single door, then this cable will be loose. If you have a double door, then most likely one spring is broken. This allows the door to open slightly, until one side is trying to lift(good spring) and the other side cannot (broken spring) Unless you are an EXTREMELY CONFIDENT DIYer then you should leave this do a door repairman as winding a torsion spring is dangerous, and can break bones or even kill. Now if your door has extension springs on each side of the track,with a pully and cable, then these can easily be replaced yourself. Check that cables are connected to the springs and the door and that one didn't break or come loose or cable off pully and binding.
Oct 21, 2010 | Garden
How does the spring attach to the pull cord after you get it wound back up?
The outer spring should attach to the cord spool in a recess or post. Wedge it to keep it from unwinding, attach the inner cord end and thread it around the spool until nearly wound. Feed it out of the cord port and pull the cord out which winds the spring some more. Make sure the cord can reach full extension without binding the spring (don't let go of the cord!!), clamp the cord with locking pliers, and fit the handle. Melt the cord ends to prevent the knots from pulling out and be sure the cord turns the engine in a CCW direction when pulled!!! Hope this helps!
Jun 20, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replace starter rope spring part no 545008013 on the poulan p3416 chain saw. How to get the spring coil seated in the housing, and then get the starter rope part on top of it.
Hook the spring at the inner mount, then wind the spring CCW until the spool assembly can be attached to the outer spring, then continue to wind the spool until the spring is about half-tight or so. It must be able to wind about three or four turns more without becoming 'bound' which would lock the spool and not permit return of the cord. When the spring is wound, wedge it so that the cord can be attached, the work the cord around the spool so that the outer end will only project beyond the cord port a little way. Pull the cord out to make sure that the spring doesn't bind at full extension, the apply locking pliers to the cord to be able to attach the handle. Melt the cord ends to prevent the knots from pulling out. Hope this helps!
Jun 15, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Our extension housing cracked, during replacement a spring came off a metal guide somewhere near the bottom right side of the case. how does it orientate?
SOUNDS LIKE PARKING PAWL SPRING CAME OFF,ONE END ATTACHES TO THE TOP OF THE PAWL THE OTHER RESTS AGAINST THE BOTTOM OF THE CASE
Aug 08, 2009 | 1990 Subaru Legacy
Long drive belt cant remember how to put spring back on
The 'j' hook hooks over the transaxle and just hangs there. The spring attaches to the stabilizer rod (reference # 43) and the other end attaches to the "j' hook hanging on the left axle.
Jun 20, 2009 | Mtd Garden
Garden Logo
184 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
