Question about Epson Office Equipment & Supplies
How to connect more than one printer to my computer. so i can alternatate use each one at different times
  • 39 Answers
You can use a printer that is wireless capable so that you wont have to directly connect that to the PC. for example you can use one printer that is directly connected to the PC at the same time you can use the 2nd printer that is wireless.
Posted on Sep 11, 2010
My Officejet 5610xi All-in-One will not print from my computer. The printer tells me it is not connected to my computer
try to check the cable or the usb connection from the computer to the printer it must be loosing or not connected properly to the interface. Install the the driver camed with your printer to your computer to be able to use it.
CHARCOIS
Oct 17, 2008 | HP Office Equipment & Supplies
How can I connect two Epson Stylus 1400 printers to one XP computer?
you should be able to connect both of them with USB, when they are connected (doing one at a time) name one differently fromt the other. When you go to start and 'Printers and Faxes' you can change the name of a printer by pressing F2 while its selected. This way you can tell the difference between the two. But the two printers should have two different itentifiers to XP and hense letting you connect both of them.
Jun 25, 2010 | Epson Stylus Photo 1400 Printer
Shows printer not connected when it is
Change the cable between the computer & the printer.
Try connecting to a different port on your computer.
Try connecting the printer to a different computer (laptop?).
If all else fails, take the printer to a qualified technician, for better trouble-shooting.
Apr 25, 2010 | HP Photosmart 3210 Printer
I haven't used my scanner for some time and now it won't work. A message says can't communicate with scanner, check scanner, may be not connected. we took it with us this winter but have checked all the...
Hello.
Either the driver is corrupted or the scanner component is faulty.
Reinstall the driver for your device. If still a problem and the other functions work, but not the scanner, the scanner part is faulty.
Hope this helps.
Apr 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Istalled another alternater yet my battery is still going flat.
change or charge the battery and make sure you install the correct alternator capable of supplying the correct amps your car needs otherwise it wont charge correctly/ check your electrical wiring it must be grounded somewhere or the connection is incorrect thats why ur battery drains...
Apr 06, 2010 | 1995 Toyota Pickup
Ford alternater
Yes, no problem. Most of today's alternators are a 1 wire type, with built-in regulators. Just pick out one from 'pep boys' er elsewhere; they can detail the connections for you. All that is left is to make a bracket to adapt to the old ones location.
Oct 09, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Temperature sender
Try removing the battery cables so the computer will be reset. Leave it off for about 15 minutes. Then reconnect it. The computer will reset to the default settings. Every time the battery is removed and stays disconnected for 15 minutes or more, it will reset itself.
Jul 01, 2008 | 1998 Ford Escort
Pause & ready led blink alternatly after initilize
Check if the paper type is set correctly (in thebackside right there is a lever to set continuos paper, or single sheets).
May 03, 2008 | Epson FX 1170 Matrix Printer
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
