Question about GE Profile Spectra JGBP79 Gas Kitchen Range
How do I replace the gas oven thermostat - GE Profile Spectra JGBP79 Gas Kitchen Range
  • 101 Answers
That has a oven sensor, thin tube left rear wall two very thin wires to the back
Posted on Sep 12, 2010
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
Oven keeps switching off
Hello
First double-check the gas supply. Look over the gas valves on the back of the oven to make sure gas is able to flow into the oven. If those look OK, call the gas company to see if there has been an interruption in service to the area or to the house.
If the oven grows too warm, the thermostat might malfunction and the thermostat is probably to blame for what you are experiencing.
The thermostat is the part of the oven that tells it when it has reached the desired temperature, shutting off the heating process. If one of the thermostat's components is broken or dirty, this can render the thermostat useless.
Cleaning and replacing the thermostat components is a process best left to professionals because untrained hands can easily break a thermostat that simply needed cleaning. If you suspect this is the issue, contact your local gas company. Sometimes, gas companies offer oven thermostat repair services.
Apr 16, 2010 | Thermador SC302T Electric Double Oven
It seems as if the thermostat for the oven is not working.
GAS UNIT:ELECTONIC IGNITION
1ST MAKE SURE .(IF ELECTRONIC IGNITION, CHECK TO MAKE SURE THE PLUG FOR YOUR STOVE IS PLUGGED IN. IF IT IS PLUGGED IN AND YOU CAN'T GET IGNITION, THEN CHECK FOR TRIPPED BREAKER OR BAD PLUG IN OUTLET, OR GFCI RESET SWITCH IS NOT TRIPPED. IF ALL IS OK THEN MAKE SURE YOU ARE GETTING GAS TO THE UNIT. CHECK SELECTOR KNOB FOR PROPER OPERATION OR CRACKS TO MAKE SURE IT IS OPERATING PROPERLY. IF ALL IS OK THEN REPLACE SELECTOR SWITCH,THERMOSTAT IS CONNECTED TO THIS SWITCH.)
GAS UNIT:NON ELECTRONIC IGNITION
1ST MAKE SURE ALL PILOTS ARE LIT. MAKE SURE YOU HAVE GAS COMING TO THE UNIT. IF ALL IS OK, THEN DO THIS:
REPLACE OVEN SAFETY VALVE OR THERMOCOUPLE OR ADJUST THE FLAME HEIGHT AT THE OVEN PILOT. ALSO CHECK OVEN SELECTOR SWITCH FOR CRACKS OR PROPER OPERATON. CHECK THE SELECTOR SWITCH 1ST. IF ALL ARE OK THEN TURN OFF GAS TO THE UNIT FROM BEHIND THE STOVE AND REPLACE THE SELECTOR SWITCH, THE THERMOSTAT WIRE IS CONNECTED TO THIS SWITCH.TURN GAS BACK ON AFTER REPLACING THE NEW SWITCH AND CHECK FOR GAS LEAKS.
ELECTRIC UNIT:
CHECK THERMOSTAT KNOB FOR PROPER OPERATION. MAKE SURE IT IS NOT CRACKED. IF NOT CRACKED , LIFT OVEN TOP AND CHECK FOR LOOSE WIRING. IF ALL IS GOOD, CHECK FOR CONTINUITY ON UPPER AND LOWER ELEMENTS. CHECK BY REMOVING ELEMENTS, GET MULTIMETER, WITH ELEMENTS REMOVED, TURN METER TO VOLT/AMPS AND TOUCH RED TEST WIRE TO ONE END OF THE ELEMENT AND THE BLACK TEST WIRE TO THE OTHER END. IF IT READS OR MOVES AT ALL THE ELEMENT IS GOOD. TEST THE OTHER ELEMENT THE SAME WAY. IF ALL IS GOOD, RECONNECT ELEMENTS INSIDE THE OVEN. REPLACE THE ELEMENT. YOU CAN ALSO CHECK FOR VOLTAGE TO THE SELECTOR SWITCH WITH THE METER TO MAKE SURE IT IS GOOD BEFORE REPLACING THERMOSTAT.
Apr 13, 2010 | Kitchen Ranges
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
There is no gas going to my oven. Only the
hello, i can help you. first of all, if the broiler works then you must have gas coming into the stove. as far as getting to the gas line, it is in the rear of the stove. typically you have to pull out the stove to get to it. that said, here are some things to consider.
Not all gas ranges/ovens require electricity. If yours has a clock, electronic igniters, self-cleaning, or any other electrical features, the unit needs electricity to work properly. Check to see whether there's power getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
It won't bake If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the item takes far too long to finish, you probably have a weak bake igniter. Often, you need to replace the igniter, but you may want to troubleshoot the oven's electrical system further to more precisely locate the defect.
  • When the temperature is consistent but too high or too low, the oven thermostat or sensor is either mis-calibrated or defective. If your oven uses an electronic temperature-regulating device, you may have an electric sensor in the oven instead of a mechanical thermostat. If the oven temperature is off by 30 to 40 degrees in this type of unit, you must replace the sensor.
    On many units with a mechanical thermostat, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jun 22, 2009 | Ovens
Thermostat seems ok, but gas won't flow from oven burner.
Hi, Even tho the ignitor is glowing, it is getting weak and will need replaced. The ignitor is not pulling enough amps to open the gas valve.
This is very common problem with the gas ovens.
If I can assist you further, please let me know.
Vic
May 29, 2009 | Garland H283 Gas Kitchen Range
GE Profile Spectra JGBP79 Gas Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
