Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Hi I have a liftmaster garage door opener. It has been stopping alot during the opening and closing process. Nevertheless, it has continued to work. Now when I hit the main button on the wall, it only turns the light on and I hear another click. It then has a blinking yelow light up on the motor casing mounted to the ceiling. The chain has stopped moving altogether and now I have to use the door manually. What Happened? Plz help!!! Tami
There are a couple of different models out there but they are all pretty much the same. Have you tried running the operator with the door being in manual mode? If you have not, push the wall button and see if the operator does anything.
If the operator runs fine without the door attached then try this:
Look for 2 blue tear drop shaped knobs, if you have a one light bulb or a 2 light bulb front and back those knobs will be on the back. If you have a 2 light bulb side to side, the knobs will be on the right side (right next to where the wires hook in to the operator). Turn the knobs slightly clockwise. The door should then move. If it moves more than it did but still stops, tweak them just a little at a time.
Let me know if this helps or not.
Posted on Sep 11, 2010
  • selinaarnold Sep 13, 2010
    I tried turning the blue buttons, I have the 2 light unit. Nothing changed. the lights come on but the chain or motor does not make a sound. Whetther in automatic or manual mode. The small yellow blinking light on the operator comes on when I hit the wall control button, and will reset when I hit the Red button next to it. But then comes on again if I push the wall control button. Sound like anything familiar? I did not get a manual when I bought the house. HELP?
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
Feb 08, 2016 | Building Materials
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont go completely up
on the machine there will be a couple mini dials to be turned, these are the ones used during installation to get the correct distance for closing and opening, they should be labled, but not all are. one is for open adjustment, and other is for close adjustment. carefull, they can be verry touchy, meaning the slightest turn can make it move alot. a general way to adjust them is a half turn is equivlent to about 2" door movement.
good luck
Jan 01, 2011 | liftmaster Chamberlain Garage Door Opener...
Garage door wont close with remote control or home link in car. Will only close if continuously hold wall mount button during entire door travel
thanks w/d for getting right on my problem,my closer doesnt have lights at the bottom, it's a garage sale deal. works good otherwise exept I have to hold closer button on the wall to close.
Dec 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
You need to do is shade the eyes some how for th door to work. What I did was remove them and put them up by the opener so the sun does not get to them.
Mar 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light flashing after opening
look in your book it will tell you the problem count the numer of blinks
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Flight flashing on liftmaster 2000
Apparently this problem is caused by weak batteries in the remote, I changed them and that solved the problem
Steve
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
117 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
