Question about Weber Baby Q Grill
Have a webber baby q that is not heating up very hot never really worked well(imho) from new but now the flame while blue is less then 1/3 of an inch high anf does not get hot enought to cook very much. i treid to cook some fish (1 and 1/12 ppunds everything seams to work ok and have cleaned everthing but it still took took 45 min to cook any ideas ??
5 Suggested Answers
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
cadesertmax
  • 274 Answers
SOURCE: weber kettle with gas conversion kit from webber -
Try replacing the regulator.
Posted on Jan 10, 2010
cadesertmax
  • 274 Answers
SOURCE: How do I take my Weber Genesis grill apart to
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
  • 512 Answers
SOURCE: weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Posted on Feb 25, 2010
Hot surface igniter will glow and put out a flame but is not a blue/orange flame
First you need to get a nice blue steady flame to prove to the ignition module there is flame. Check you orifice and bypass tube.
Feb 22, 2014 | Lincoln Impinger 1116 Gas Oven
Hooked up roper dryer and it's propane everything seems to be hooked up right but won't get hot or even heat up. This is first time ever having to use propane. Any idea what it might be or could have...
1.is the pilot light lite burning.
2. if pilot light light is on ,does the blue flame of the pilot light touch and heat up the thermocouple.
the dryer will not turn on the heat if the pilot flame does not touch and heat up the thermocouple.
3 is the dryer plugged in to the electricity.
4. is the dryer actually getting electricity.
If the dryer has electricity and the pilot flame is touching the thermocouple, then try buying and installing a new thermocouple.
****have you purged the air out of the gas lines so that the dryer is actually geting pure propaine and not just air getting pushed ahead of the propaine.
how old is your dryer, if new, warranty service will trouble shoot & repair for free.
you need to tell us more so that we have some facts to work with. vagueness does not cut it.
Oct 09, 2013 | Dryers
My hayward model H350 will heat the pipes up so fast it will melt the cpvc fittings out of the supply lines. How high should the flame be and how close should the flame be to the heat exchanger pipes...
Where was the 7in reading taken? Inlet or Manifold? With or without the burners running? You probably want to look at the manifold side and adjust the regulator in the valve to get pressure on the manifold side down based on the assumption your pressure is to high somewhere to get a 7-10" tall flame on the burners.
Dec 02, 2009 | Pool & Spa
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
May 18, 2009 | Weber Baby Q Grill
Boiler flames extinguish and reignite regularly
what about flame rectification probe (flame proving probe)
Nov 30, 2008 | Combi Centre DX - Mango
Propane tank with regulator
You're fine using a regulator, just keeps the propane 'regulated' : ) Since you already have it, I'd try the one you have. I'd figure your regulator for the big tank is set for low pressure, really may be fine by itself, but the additional one at the Webber end won't hurt anything. This is a YMMV, try cheapest way first using what you have, not much of a problem to change to the other one if it doesn't work.
Oct 29, 2008 | Weber Baby Q Grill
Gas oven not heating
waka,
I'm guessing that there is an issue of some kind with flow of heat inside the oven. Gas ovens use the hot air/gas exhaust to heat up the oven. Flames mean heat. The flames should be about half an inch long or so. If not, there may be an issue, but I don't think that is it.
Have you lined the oven with foil? It is possible that vents from the boiler section are closed up? That will prevent heat from reaching the oven.
Dec 03, 2007 | Whirlpool SF367 Gas Kitchen Range
Weber Baby Q Grill Logo
21 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
