Question about Woods Upright Freezer MU07W
Mm Wood's Freezer model # F17WCE is condensing water at the bottom. The openining at the inside back is draing water to the bottom forming a sheet of ice. Solution?.
4 Suggested Answers
fixitallguy
  • 11 Answers
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Posted on Jan 25, 2008
SOURCE: there is water from somewhere in my woods upright
Sounds like air infiltration gasket issue or power outage? proper freezer bags will stop the burning.
Posted on Nov 01, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a 17 cu
Usually you can access a service panel to where the fan and evaporation department is.
I don't know about a wood but I did work on an upright not long a go and took some pics.
See the drain hole below the fan on the floor there?
Thats what ya gotta clear. I use a shop vac myself but I let the freezer thaw all the way out , you could use a hair dryer to melt the ice.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 13, 2011
Wood freezer f17wce bottom ice
There is water accumulation at the bottom under the basket it forms a thick piece of Ice that we have to break in order to remove it every second day what can I do ..
Feb 24, 2014 | Woods Upright Freezer MU07W
Model No.ERF415M 13CT. I have ice forming underneath the bottom freezer draw, when I open the door it melts and runs out as water under the appliance.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
Aug 23, 2011 | Daewoo Freezers
I have a 17 cu ft. frost free freezer, Model F17WCE and I believe the tube is clogged. I thought if I found the plastic tube, I would wash it out. I saw the tube from the front of freezer, while lying on...
Aug 13, 2011 | Woods Upright Freezer V1613RW3
Loose handle
bottom of handle is a screw hidden behind a square little sticker thing. use a small screwdriver to pry it out. take out screw and then push handle upwards and it will come off a clip which you can now tighten. then snap top secti0on of handle back onto clip and then lower screw secures it.
Nov 09, 2009 | Freezers
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Condensation forming on the bottom of freezer
Referred back to the manual and installation requires 3" of space on sides and back. Moved the freezer to comply with that requirement and problem seems to be resolved.
Jun 05, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
Sep 23, 2008 | Maytag Freezer MQU2057
Upright freezer
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 14, 2008 | Freezers
Woods Upright Freezer MU07W Logo
94 people viewed this question
Top Woods Freezers Experts
Sal De
Mike Squire
Are you a Woods Freezer Expert? Answer questions, earn points and help others
