Question about Samsung Televison & Video
I have a 52 inch hd samsung.Wheh I first turn the tv on,the screen shimmers on the right side.How can I adjust it to get a normal picture?
  • Samsung Master
  • 11,800 Answers
The image shimmers because the panel driver board - the one that converts the data coming from the image processor in the actual data displayed by the screen:  Y-sus and Z-sus for a plasma, t-con for an LCD -  is about to die, a component is failing. You need to open the tv and test the board to identify the failing part and replace it if possible - if not then the entire board will have to be replaced for a cost of about $100 plus labor.
Posted on Sep 11, 2010
How do I adjust my screen
Look for picture size or zoom on remote...
Oct 28, 2014 | Samsung Un55c6400 55 Inch Led Hd Tv - Free...
How to adjust picture setting on 23 inch samsung tv cant get to advanced settings .have direct tv no hd but the picture is not very clear at all.thanx
Samsung LCD P2370HD 230?N when I turn on the channel is switched on after a few seconds the LCD screen is black and none of the menus do not work and the state remains a solution to this problem is?
Aug 08, 2010 | Samsung P2370HD 23 in. TV
No picture only sound ( plasma 52 inch )
Hello Fixya customer,
Thank you for your question.
There are several possibilities here including the signal source, a fault in the video processing, or panel display drivers.
This can be narrowed down further for your model. Please supply the full model number of your TV.
Thank you for using Fixya, and I look forward to your response.
Apr 29, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
After my ciurcut breaker was fliped on and off my samsung 46" 71f has had problems
Ive had a element lcd tv that i bought, out of nowhere the power cut off, so i went to flip the breakers, and since i had the Tv still plugged up, after i flipped the breaker to get the power back on. Power came back on, went to go turn on the tv, the light would be on but nothing on the screen no picture. Sometimes it would come on a little bit after awhile but that is it. So yes i do recommend you have there tech come out and fix it. Before you ever flip a breaker off and on, unplug all computers, tv's, anything in that nature before you do it.
Oct 31, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
1 inch lines on top and bottom of screen
Is the picture overall too small by 1 in. on top and bottom? Or is it cut off by the lines?
If it's too small, look for an adjustment labeled Vertical Height. This may only be accessible internally, it's normally a service adjustment, not a user adjustment.
Your problem is a vertical deflection issue, either an adjustment or the vertical circuit requires repair by a technician. In the latter case, electrolytic capacitors are a likely cause.
Oct 17, 2007 | Televison & Video
Tv screen
try, mcmelectronics, vancebaldwin.com, tritronics
Oct 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung LCD TV shimmer problem
Are you sure this is not an LCD screen door effect, It is a normal thing for this to happen to an LCD TV set. They are not made to be watch too close or you will magnafy this normal effect with the screen. If you have a problem with a new set, dont waist any time and get it service right away as it will cost you a small fortune in the future to have it serviced. Good Luck
Mar 24, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
