Question about LG WM-2277HW Front Load Washer
I have a LG wm-2277hw front load washer. The inside drum seems to be out of balance. What do I need to do.
    Problem Solver:
  • 15 Answers
Hi dear it seems that you need to change rollers seal and maybe the axis IF UR WASHER IS NOISY if not you have to check the tub supports up and down.
Posted on Sep 11, 2010
What does Lg front load code dHE mean?
Your 2277HW has a heater element inside the drum.
Error 'he' means computer has detected open circuit to
water heater.. Most likely broken wire at the heater or nearest wire tie
securing the heater wire to the tub. Disassembly of front of washer is required to inspect / repair.
Aug 17, 2014 | LG WM-2277HW Front Load Washer
My washer is off balance during the spin cycle it jumps, and moves around
With the washer empty, tilt it front a few inches and drop it back down. This will re-level the legs. If it still jumps around, replace the drum snubber, inside the front of the machine. It's a rubber pad that keeps the drum from moving around too much. Snubbers dry out with age.
May 07, 2011 | LG WM-2277HW Front Load Washer
Leaking water under drum area seems to leak more with larger load
Check the gray rubber seal by the door. Look all around, inside the folds, for a hole. (usually found on the right or left side) Replace door seal if hole found.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
Drum seems to be out of balance. Last two load came out wet. Drum also hit the sides of the washer.
The loads I do with towels always end up with the display UE which is imbalance error, this happens with 1 towel as well as several towels. What can I do to resolve this imbalance?
Sep 24, 2010 | LG WM-2277HW Front Load Washer
Washer drum is out of balance and front boot is all twisted
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 09, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer. I am trying to remove the big nut
the best way is to have some one hold the drum from the front and turn the nut. it can also be done sometimes by turning the drum in the opposite direction and then pop it with the wrench. not the best way but it works.or you can hold the stator assy with one hand and tap your wrench with a hammer.i hope thia was helpful,would like to here how things worked out.
Jan 22, 2010 | LG WM-2277HW Front Load Washer
LGWM2277HW Front Load High Efficiency set Code "LE"
may be a belt problem since you have this sound
thank you
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Apr 15, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
181 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
