Question about Garden
Ihave a Rally mower with a Vector Tecumseh 5.5 hp model #4v582b, now starts every time I prime it but quits for the first 4 or 5 primes then runs but surges all the time can you help
  • 143 Answers
Sound like a dirty air breather filter or dirty carb. jets. Remove carburettor and blow out with air. Stephen
Posted on Sep 11, 2010
Mower starts when primed but stops when the primed fuel is used up
The jet in the Carb is gummed up. Take that 1/2" bolt off the bottom of the Bowl..That IS the Jet. Many times the Bowl will just hold in place with the Bolt out.. make sure the three holes are clear. 2 are close to the head of this bolt and you should have a real small hole where the threads end. Screw it back in...see what happens
Sep 16, 2012 | Tecumseh Garden
I prime my tecumseh engine three times as stated. The lawn mower still will not start. How do I investigate to figure out what is wrong? I have taken it to a repair man twice. After I get it back it will...
This sounds like a fuel delivery problem. Maybe remove the carb and tear it down and then soak it overnight in a cleaner after removing all the moving parts...not real hard normally...then let dry and reassemble...If this doesn't improve the fuel delivery problem, maybe get another carb for it....Make sure the air filter is not plugged up, blocking air flow to the carb itself..just something to make sure of at first.
Jul 17, 2010 | Toro Lawn Mower With Toro Power Tools
Totr model #20479 GTS 5 motor, when you push prime
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 16, 2009 | Toro Lawn Mower With Toro Power Tools
Troy bilt 5.5 tecumseh engingine only stays running when primed then quits...
It sounds liker the jet in the bottom of the carburetor is clogged. You will need to clean it out with a piece of small wire and the engine should be able to get some fuel to run.
Oct 06, 2009 | Garden
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
No priming bulb on flymo petrol mower
hello
if JLO engine (normally silver colour) the primer is on top of the carb you press it down
if tecumseh (brown colour) the primer is on the bottom of the carb and you press it up
hope this helps
Mar 15, 2009 | Garden
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
