Question about GE Advantium 120 Convection/Microwave Oven
Model SCB1001KSS01 - GE Advantium 120 Convection/Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Need to find a manual for bread machine , brand name: Wel Bilt. model number:ABM1H70
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the word MANUAL + the abbreviation PDF to perform an Internet search. Google is best for these types of searches.
Example: If you owned the Fredericks Home Bakery model KHB-178 you would want to enter your search as:
FREDERICKS HOME BAKERY KHB178 MANUAL PDF
Hope this helps & Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 23, 2011 | Microwave Ovens
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
How do I change the light bulb in my Advantium Micro Wave. Model is a 120 number SCB1001KSS01. Please send me instructions. Thank you. Karl kflorian5@gmail.com
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 01, 2011 | GE Advantium 120 Convection/Microwave Oven
Have model jvm1740sm1ss ...keypad has shorted ...cant seem to find parts for this model even on ge site
This should be the correct parts listing for the model number you have provided:
http://www.pcappliancerepair.com/model.php?mn=JVM1740SMSS01&man=&mid=&brand=GEH&pmid=0
Here is another part listing which is a slight variation of your model. The part numbers are still the same, however:
http://www.pcappliancerepair.com/model.php?mn=JVM1740SM2SS&man=&mid=&brand=GEH&pmid=0
I believe the model number should read "JVM1740SMSS01". If you have any questions, please post back and let me know. I hope this helps you.
If these links do not work, go to pcappliancerepair.com.
Here's another listing available at appliancepartspros.com:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218277
Here's another listing available at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JVM1740SMSS01/0432/0123370?searchedModel=jvm1740sm&blt=
Oct 28, 2010 | GE Microwave Ovens
Just wanted to know the size of the GE profile microwave model JVM1660BB005. Is it 1.5 cu ft? Looking at a new model JVM1540LNCS to replace it and want to use the same mounting hardware.
In GE microwaves, the first 2 digits of the model number are the cubic footage. 1660 is 1.6 cubic foot, 1540 is 1.5 cubic foot. Take care trying to use the existing hardware, the exact placement of hardware and upper installation screws may vary from year to year or model to model..
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
THIS MODEL JUST WENT OUT, WHAT WOULD BE THE NEW REPLACEMENT MODEL
Please reply back with your brand and model number so we can help you.------------------------------------------------------------------------------------------------------------------------ Please reply back with your brand and model number so we can help you.
Aug 19, 2009 | GE Microwave Ovens
Model no. correct??
It doesn't look like a valid Magic Chef model number.
The word "model" will appear beside it on the model / serial tag on the unit.
Also, you can check this page for recent Magic Chef models.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 07, 2008 | Microwave Ovens
GE Advantium 120 Convection/Microwave Oven Logo
89 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
