Question about Kenmore Oasis HE 27082 Top Load Washer
We just went to use our 3 year-old Kenmore Oasis (110-27072603 Type 580) HE washer and have run into a problem. The machine starts, water pumps in, it makes some odd noises and then the power cuts off and it goes dark.. It comes back on then off again repeatedly, with the whole unit going dark each time. No error codes given. Anyone experience something similar?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#!#
Posted on Sep 30, 2010
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
I have a kenmore elite oasis washing machine, type 580. when starting cycle it stops with code F 50. Any suggestions?
It's telling you that it did not detect motor movement. This could be failed motor control or something else. It is probably an RPS or the maching/motor control board but there are a few other things that it could be. Not an easy problem for DIY.
Jun 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Elite Type 580 flashing LF
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have kenmore elite oasis, type 580. when starting
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!!
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis won't completely drain and flashes "LD"
Does the pump keep running and then shut off first if so you can try this .It is not the proper way but sometimes you have to wait for the machine to go into the spin drain cycle and tilt it gently a few times like an old pinball machine. I sometimes have to do that. but I want you to know it is not the best for the machine you could break something else while doing this
Dec 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Sep 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Need diagnostic test for Kenmore Elite Oasis HE top load washer it is making beeping noises and has a mind of its own
pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Jun 21, 2008 | Washing Machines
Noise sounds like loose change or screws.
You probably have something in your pump. Remove the lower front panel (3 #20 torx bit screws) In the bottom, middle there will be a large white pump. I usually remove the screw holding it in so I can get the edge of a bucket underneath it. Once you rotate the knob in the centercounter-clockwise and the water drains out, remove any forign objects.
Jun 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
226 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
