Looking for reset button on fisher amplifier ca-9635
4 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: need to locate the microprocessor on the fisher
Yep, that is a likely problem, but it could be a blown diode in a relay switch, or etc. etc. If you're lucky, someone will possibly have a repair manual, and schematic. That way, you could reset it, but maybe ohm out a few components further up the on/stand-by circuit while you're in there. Sometimes you get lucky and it's easy, but it can be tricky. I would take digital pics or videos as I went, using macro when necessary. Makes things much easier for me, anyway. You can possibly purchase a schematic, but I couldn't find one online, so if you can get a current tech line, you could probably go that route, but I'm thinkin' big bucks. Here is a blog about your problem, and although there isn't a schematic that I saw, it does identify the components in "stand-by" circuit, as well as the microprocessor.
http://www.freelists.org/post/techassist/Fisher-AMP-CA9025DEADmore-info,3
Gutsy job, but that's the only way to keep them alive, from what I've seen! Good luck!
Posted on Mar 27, 2010
  • 357 Answers
SOURCE: My fisher amplifier ca-854 switches
well could be a few things. It could be the input source. so if you are playing a cassette, try cd or tuner and see if the same happens.
Could be dust in switches so wiggle and push the function selector controls and see if it gets any better or worse.
Could be bad speaker terminations - Try removing speaker cables, re-stripping and re connecting at both amp and speaker end.
Possible dust in the volume pottentiometer so with the power off, move volume up and down franticallly (but gently) from min to max for about 15-30 seconds) to clear out any loose particles.
If these small things should not work, please reply back with anything you've noticed from these tests and I will try and aid you some more
Posted on Jan 16, 2011
SOURCE: Fisher Stereo Intergrated Amplifier CA 9025 is
just bought a ca-275 that i cant seen to get any sound to come out of. but im also testing it with car speakers. is this my culprit
Posted on Jul 18, 2011
How so i get a Fisher CA-854 amplifier to work without the remote control
Press the buttons on the unit. Which means getting up.
Sep 12, 2014 | Televison & Video
CA-9025 amplifier the out speakers relay doesn'tsw.
It is possible that the error protection is ON and so does not switch on the amplifier to the speaker. Only if the error amplifier which is a current sensing circuit gets a good feedback on normal current drain will the processor be informed for the speaker relay to be switch.
So remove speakers and check, if not the output is faulty. check for short or drain in at least one channel.
Feb 07, 2011 | Fisher Audio Players & Recorders
HI I have fisher integrated stereo amplifier model CA-885, it was totallydamaged.I would like to by new one will you please help me. gasim
Hi, I came across this model amplifier in a Goodwill today - was checking online about specs (which is how i found your post) to see if it was worth purchasing and reselling. If you're still interested please drop me a note directly at jtimleck &&**##_at_%%$#@mac *&^ dawt calm
Oct 15, 2010 | Audio Players & Recorders
Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Dan
Jul 06, 2010 | Audio Players & Recorders
Need to locate the microprocessor on the fisher ca-9025 stereo amplifier. Need to know where it is and what it looks like. This is so I can repair the problem of the stero not going off stand-by....
Mar 27, 2010 | Fisher Audio Players & Recorders
Fisher Model CA-270 amplifer. Audio select not working.
When you state that you can not select a device, do you mean that there is no sound, or that the device selection is not happening? A few more descriptive details will help here.
Thanks,
Dan
Feb 02, 2010 | Audio Players & Recorders
Fisher Stereo Intergrated Amplifier CA 9025 is stuck on standby
Oct 14, 2009 | Fisher Audio Players & Recorders
Fisher ca 9025 amplifier
The amp is in protect mode. Something in the final stage is defective. This is usually caused by shorted output transistors. This unit is worth getting repaired. Expect a parts cost in the $25-$50 range.
Dan
Dec 03, 2008 | Audio Players & Recorders
For those who accidently put thier CA-9025 in standby mode by hitting the timer button and no longer have the remote, I figured out how to turn them back on.
Turn on the power button and press and hold the Tuner button for at least 10 seconds. it should come back on :) Hope that helps.
May 08, 2007 | Fisher RS920
124 people viewed this question
 Grubhead
Grubhead
