Question about Whirlpool Refrigerators
Whirlpool Fridge Mod-ED20TQXFX01. No water is coming into ice maker. Removed plug from water supply solenoid and applied power-water then flows into tray. Arm is down on ice maker.
  • 1 more comment
  • paco2714 Sep 11, 2010
    The solenoid does work and allows water into the tray when energized. Are there any other pointers that you can suggest may be the problem?
    There is something that I'm missing here. If I apply power to the solenoid with jumper leads to external power and the valve opens and works, wouldn't that suggest perhaps that the controller or some other switch is not supplying power to the solenoid? The solenoid that I am referring to is on a bracket on the lower rear of the fridge on the rht. side.
    I will take your suggestion and replace the solenoid! I will let you know what I find out. Thank-you!
    President:
  • 3,773 Answers
Check water valve at back Its where the water line attaches to it.
Check water pressure
Pour a cup of water in the ice maker, if it ejects ice later then that
valve is probably defective
If it doesnt then the icemaker is defective
Also check temp of freezer should be below 10 degrees
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Posted on Sep 11, 2010
  • 2,382 Answers
Sounds like a solenoid problem. An electrical valve that opens to allow water into the tray(s), then closes when they are full (usually by a timer). The valve may be defective or the control circuit for the valve. A plugged filter could cause symptoms like this too, but you will usually have some water coming out into the trays.
But with no water and the fact that you had to apply power before water flowed into the tray, then it is the solenoid.....
  • Tunde Autos
    Tunde Autos Sep 11, 2010
    It doesn't need to be energized before it works. The solenoid is faulty if you have to energize it...
  • Tunde Autos
    I understand very well what you mean and am also certain of my answer because i have dealt with similar issues like this before, but if you feel it has to do will a switch or power related not getting to the solenoid, you can trace to confirm that before changing the solenoid...
Power to ice maker but won't make ice
Hallo
1:At the back of the Fridge at the bottom there will be a water inlet splitting up in two separate pipes, each supplying a solenoid.
2:Trace the pipes from there and see witch pipe flows into the Freezer(usually its the one on the right hand side).
3:Now turn the fridge of and place your hand one the solenoid and turn it on, you are suppose to feel a bit of a shock(kick) witch tells you it opens up and can supply the ice maker with ice.
If it does supply the ice maker then the controller(cycle timer) on the ice maker if faulty and you should order a new controller.
4:If so send me the brand name of the fridge with serial and module number and your country and city and ill get the nearest suppler to you.
Regards
Jun 25, 2016 | Refrigerators
No water
If you are getting ice then you still have a water supply. If not then make sure the water is turned on behind the fridge. I would next check for power to the solenoid when the door switch is pushed. Then check to make sure there is power to the switch. My best guess it that you have a faulty door switch or the wire was accidentally loosened or taken off when the person was working on the ice.
Apr 14, 2014 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Have a top freezer MOD # ET4WSKXSQ01.. SER#VSW3914735
The ice maker kit you need , is IM1 kit . This comes with an icemaker , tube , water valve and everything needed to install . Instructions are included .
May 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
26 side by side with ice maker doesn't work
The water control valve can get clogged or fail. Follow the line from the supply( did you check for filters there?) to the bottom of the fridge. The valve may be just like the one on a washing machine. It has a wire filter in it too. Test it for flow, unhook the pipe to the ice maker and see if water comes out of it when it is energised. I made a test energiser out of a power cord with the same connectors that the valve has.
Apr 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
Water dispenser no longer works.
Where the water supply connects to the Ref there is one water valve but, two solenoids. One for the water and one for the ice maker. An OHM meter will tell you if these solenoids are good.
Solenoids good;
Set the meter to volts and check if power is getting to the water solenoid while pressing the water despensor. No power, bad switch.
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking from freezer down to refrigerator at a slow drip.
There is a solenoid that controls the water flowing to the ice maker in the freezer. It is usually near the bottom of the fridge on the back. It may be covered by a cardboard or metal back that is easily removed by taking off a few screws. There will be one water supply line coming into it and one or two water supplies going out. When the solenoid begins to fail it sends water to the ice maker when it doesn't need it causing an overflow in the ice tray which leaks down into the freezer giving it a kind of glacier effect. Real easy fix though. Just replace the solenoid on the back of the fridge. I bought one online for around $20 and it is very easy to do. If you have water in the door and an ice maker it will be a dual solenoid. Turn off the water supply, disconnect the water lines,  take the solenoid off the fridge to get the part number. Google it, Get it, put it back in the way you took it out, turn the water supply back on and your back in business without a costly ripoff technician.
Nov 05, 2008 | Refrigerators
Ice Maker
  1. Water comes from water pipe, usually with a shut off valve (open??).
  2. Fridge has a small filter (for sand etc.) at inlet. (not clogged??)
  3. Water travels to solenoid valve, and waits for request. (do you hear it click when water requested??)
  4. Water usually goes to a fine filter..(these fail (plug) quite regularly).
  5. Water goes through storage in back of cool section (Inside fridge- is it full of water?).
  6. Water goes to ice maker on fill request.
  7. ?? Is the power switch "on" (to icemaker)??
  8. ?? Is the full / stop filling paddle/bar up?
  9. ...ask me more questions
Apr 21, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool ice maker
Hi Chubbo,
 When you say you checked the Valve, did you check the Supply valve that feeds water to the fridge, or the Solenouid valve that usually casues this problem.  Unplug your Fridge and roll it away from the wall.  Remove the  rear access panel  and trace the water supply tubing to the solenoid valve. Lots of time the valve is bad.  You  can get a replacement  Solenoid.  at any Appliance part store, or online at www.repairclinic.com
If you did check that. You can get a coupling that will adapt from the water supply directly to the line coming from the solenouid to pressure up and see if you actually have a flow problem between the solenoid valve and ice tray.
Hope this is helpful to you. Good Day
Oct 18, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
