Question about Brother Sewing Machines
Got a sewing machine from a garage sale with no manual it is a brother VX-1250 and got it all set but I can't figure out how to thread the bobbin.
    Genius:
  • 1,788 Answers
Get a copy of your manual from brother-usa.com and it is usually free to download, it will show you how to thread your machine properly as each machine is different.
Posted on Sep 11, 2010
How do i thread the bobber in my sewing machine? i have a brother vx-1500
Am unable to locate a manual for your machine, although this one may be helpful:
Brother VX 1435 Operation Manual Threading The Machine Winding The Bobbin
Sometimes, similar models operate the same.
Dec 16, 2017 | Brother Sewing Machines
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
Instruction manual for brother vx1130
This is as close as I can come, unless you read French.
VX-1400 / VX-1250 54-pages$10 + shipping
Brother VX 1140 1250 Instruction Manual
Feb 19, 2015 | Brother Sewing Machines
How would to insert the bobbin in the sewing machine brother VX 1400?
There is not much of a secret to inserting a bobbin in a sewing machine. A couple of things to check, the thread from the bobbin should be pulled through the slot of the carrier, and make sure the thread comes through the sewing hole by manually lowering the threaded needle and then lifting it out of the hole again after it has picked up the thread from the bobbin. The video link posted below is useful if you have a Brother sewing machine.
If the stitching is still not right then check that the needle is fully inserted in its housing. (Push the needle up as far as it will go then tighten the screw.)
How to wind and install the bobbin and thread the sewing machine PART 2...
Aug 24, 2014 | Sewing Machines
Brother vx-1435, needle cuts thread when sewing
change the needle it could have a burr or be damaged
also check the needle plate & bobbin area for burrs
Apr 09, 2012 | Brother VX1435 Mechanical Sewing Machine
Brother VX 1250. The needle can't pick up the bottom thread from the bobbin.
Check the needle to be sure it is installed with the flat side facing the back of the machine.
Check the needle to be sure it is not bent.
Mar 02, 2010 | Sewing Machines
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
97 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
