Question about Microwave Ovens
I have a Panasonic microwave NN T573. It's great and everything works as new except the door opening mechanism has been deteriorating for some weeks .. then I have to pull the door as I push the button (which lost its positive feel a while ago) .. now it won't open at all. I am reasonably competent diy (done a few fixes on cars, ovens etc.) but cannot see any obvious way to get to the mechanism - I assume that I can buy the part online. Also a bit nervous reading about high charge capacitors!!!!! Any help please guys?
  • 1 more comment
  • broken5746 Sep 11, 2010
    Sorry but I feel very uneasy about discharging capacitors through a pair of pliers - I am happy to leave it unplugged for a couple of days? Or, is there a better way to discharge them .. surely they have to be discharged slowly to avoid a damagingly high current?
    thnaks caroldan .. sounds like good tips here. I am going to leave for a discharge then dismantle it. Also I need to order the new part. I'll come back when I have fixed (or not!). Thanks for now.
    Thanks for that. I will allow discharge, dismantle and order a new part. I will get back to you when good or if I meet a problem. Thanks for now.
  • 3,247 Answers
Usually you will have to take the top cover off and use a screw driver to release the spring in the switch assembly holding the door latch.
I would suggest you browse the material at this site to become familiar with the appliance.
I am assumng you are based in the UK or Europe as this model of the microwave is not very common in USA.
Browse this site for the door mechanism related spares that you may need.
In case you do not have a user manual (not much help for this problem) you can get it from here.
Hope all this helps. When working with microwave ovens always make sure you turn the mains swich off and wait for 5-6 minutes and then take out the plug. This way you will ensure the high voltage capacitors are discharged before touching. Also wear insulated footwear.
Hope you are able to fix the door problem soon.
Posted on Sep 12, 2010
  • Microwave Ovens Master
  • 17,130 Answers
The door mechansim with the latch is with a limit switch that must be reset when the door is locked. The connectiion to the trigger in the mechanism through these spring loaded switches is needed to switch the microwave.... only when the door is latched.
So remove the front panel and check the locks. Use a good degreaser to was off dirt.
Now remove and reset the switch mechansim , test the continuity.
Not to worry about high voltage only if touch them. But take precaution to keep away from the magnetron when the set is on for testing with a cup of water.
Use your logic( being a DIY) to see the latch and reset.
Use a screw driver from within to trip offf the door to unlock
Posted on Sep 11, 2010
  • Donald DCruz
    Donald DCruz Sep 12, 2010
    Even with a longer duration some ccharge may remain so use a wire to short off.Take care
  • 11,800 Answers
Yes , the tension in the capacitors is extremely high but if you wait a day with it unplugged then try to start it (still unplugged) then they will be discharged. To be absolutely sure you can discharge them manually without the waiting period - just jump the plots of the capacitor with a very well insulate pair of pliers.
Once that is done just dismantle the unit completely and access the door latch (you will need to remove the face for that); if you can fix it then that's it. If not then you can order a replacement part from Panasonic or find a used one in a repair shop.
  • Azrael SRL Sep 11, 2010
    Sure, leaving them two days will  also discharge them to safe levels. But, as i said, by using a pair of well insulated pliers will save you some time and make it absolutely sure - this is why you should do it even after the waiting. Discharging them quickly  doesn't to any harm to them - it will just make a big , loud, spark. To avoid the spark (and scare the customer) i use a wire with a big resistance on it.
PANASONIC Microwave Inverter #NN-SD697S. Everything works except the START button. Works sometimes, and not other times. Checked outlet, all was good.
This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
Sep 11, 2013 | Panasonic NN-S251 Microwave Oven
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
I have a microwave oven (over the range) panasonic nnp295sf, it is having a problem that whenever I turn to start microwave on the bus fuse is burnt! when I put a new on everything works, except when I...
I presume you mean the fuse within the microwave.
If it is doing that, firstly check the door switches, if there is no problem then check the diode and capacitor supplying the magnetron. BEWARE, THERE ARE LETHAL VOLTAGES AT THAT POINT!!!
I suspect there will be a problem with the door switches.
Nov 01, 2010 | Panasonic NN-P295SF Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Panasonic Inverter door stuck
The door latch mechanism is all plastic and commonly breaks. You have to take the cover off and work on it from the inside.
Jan 08, 2008 | Panasonic NN-H764 Microwave Oven
Microwave Ovens Logo
136 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
