My top load Maytag washer Model SAV365ZAWW does not turn on and fill with water when in the hot water selection. It will turn on and fill with correct water temp. when in the warm or cold selection. Can you assist me with this problem.
  • 1,531 Answers
Check the water hose connections for any restrictions. you may need to replaced the water valve. you can also change the hoses around and try the hot water setting with the cold water supply line this will tell you for sure if it is bad.
Posted on Sep 11, 2010
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
My maytag washer fills up fine with hot water. When filling the washer with cold water it takes 17 minutes to fill.
that is a problem with the water inlet valve if your washer model number is the one listed in the question(different brand for that m#) the part number is R0131578 for the water inlet valve it could be purcahsed at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
Gene
Aug 26, 2011 | Maytag ALW432RA Top Load Washer
Washer fills with hot water even when unplugged
The freezing messed up the fill valve. This is the part that your hoses connect to on the back of the washer. Replace it and you will be fine.
Jan 11, 2010 | Maytag PAV2300 Top Load Washer
Only hot water will fill, cold water will not
If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
Sep 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Maytag model# sav365zaww squeeks
check your pump the bearings in your pump
could be going out this will cause the water not to be pumped out properly and will also cause a squeek
Dec 29, 2008 | Maytag SAV365Z Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
