Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
NHow do I get front cover off to test the washer switch?
    Problem Solver:
  • 5 Answers
Remove the two phillips head screws near the bottom of the front cover, lift cover forward and remove.
Posted on Sep 13, 2010
Everything comes on but it will not add water. I have checked all hoses and electrical sockets, but it still will not add any water at all.
  • There are 2 electric switches at the end of each water hose, going into the washer. When you push the start button, these switches open and allow water in the machine. They may not be working. Most front loaders have a test sheet uhder the top cover of the washer. Unplug the washer! ! ! ! from electrical outlet. Unscrew 4 to 6 screws around the top of the washer and slide back the top. if there is a test sheet it's here. Perform test. It is unlikely that 2 switches would go out at the same time, so it may be the control board. This is the board that has the cycle selection, and such, detergent., softener, water levels. This part can run $118 to 140 depending.
If the spec sheet is in the washer you have a shot at fixing it, if not its! harder. You may need a service call
Mar 22, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
The conditioner will not go into the drum out of the drawer
Likely problem is thqat the dispensing switch inside the washer does not work. Unplug the machine!!!
Undo the screws on the back, at the top of the machine. The top cover should cover should off, backward and expose 2 tio 3 of the these switches. Under the top cover there may be an instruction sheet, that may have a map of the position of the switches, and possibly of test codes. If it has test codes, follow the instuction to test the dispenser solenoids. If you don't hear a click when performing the test, the dispenser is likely bad. Test the other switch(es). If it/they click then you have a bad dispenser solenoid.
Replace it and problem should be corrected. Or, call service personnel if you cannot perform the ttesting described above,.
Mar 22, 2011 | Hoover AAA160 Front Load Washer
Water wont exit the machine.on the display screen it comes up saying -f.05
F05 means water level switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Reassemble and test.
Dec 19, 2010 | Hotpoint Ultima WF860 Front Load Washer
Won't spin
If your washer is not spinning you need to check this part.
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt(belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
Mar 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer wont spin out
  8. Test the motor
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fault code f-05
Error code F05 denotes the pressure switch is jammed on full.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Indesit W 123 Front Load Washer
Washer spins while washing, it will also drain with no issue but will not do the final spin? help!
Any error codes? Try putting it in diagnostic mode. You can test different cycles and retrieve error codes. Instructions should be taped in an envelope to the inside of machine. You may have to remove the bottom front cover to find them.
Most likely cause - Faulty door switch.
Oct 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
The washer will not spin
  • Hi
  • Try these:
  6. Inspect the drive belt (belt drive only)
  8. Test the motor
please rate my suggestion...
May 22, 2009 | Kenmore Elite 45986 Front Load Washer
Start/pause switch works intermittently. How do I
i have found that the micro switch burns out on them and needs to be replaced. remove rear screws remove top cover , remove shield the unclip cables and front panel
Use a multi meter to test micro swicth on circuit board replace if faultsy
Mar 06, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Washer wont spin
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
Dec 13, 2008 | GE WBVH6240F Front Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
265 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
