Question about Gateway 838GM (RB838GM) PC Desktop
When I turn on my pc it beeps three times and there is no signal to the monitor. What do the beeps mean?
  • 97 Answers
please write your beep description
ex: one long beep two short beep
repeating short beep
Posted on Sep 11, 2010
Gateway 2005 gx7022e pc was running fine and now out of no where when I turn it on it beeps three times and monitor says no signal and goes black. The tower itself is running very loudly
1)check weather the ram is properly installed on board or not
or reconnect it
2) or clean the ram with eraser n check it out
3) if still its not working den remove the ram from board n switch on the pc n check for beeps if u r getting beeps then motherboard is ok n ram has problem den replace the ram
Nov 17, 2015 | Gateway Computers & Internet
Monitor says no signal when turned on
Check the memory cards are inserted correctly (remove and reseat)
Dec 27, 2013 | eMachines W3611 PC Desktop
My desktop turns on but my monitor doesnt come on its plugged in right but my desktop just shows a light that its on
use other monitor..if it would not work listen for beep codes from your cpu.continuous three beeps meaning change your memory cards or check your memory cards..see if your monitor has light
Sep 01, 2012 | Gateway GT5220 PC Desktop
The PC powers up, then starts beeping, one long beep and one short beep. The monitor tries to come on but shows the DVI with no signal; and the HDMI with no signal and the VGA with no signal and then the...
the beeps codes means there is a problem with a piece of hardware (RAM, or graphics card ,etc)
I need to know the BIOS manufacturer to interpret the code (phoenix or award or AMI)
for COMPAQ it means BIOS error --and will have to reload it from a recovery cd.
for IBM it means system board failure-- need new mobo--for a beep code of 1 long and 2 short most all mean graphics card problem.
If this was helpful, please indicate so, if not , comment back so we can resolve this issue
Dec 27, 2010 | HP Computers & Internet
Dell Demension 9150. I push the button to turn it on and it just beeps. I tried it several time and had the same result. Any ideas on how to fix it? I do not have hardware experience. Thanks
if you the beeps are long, means that you need to replace the memory module. if it is a short beep, and your monitor is black:
  1. remove the video cable if your monitor display 'No signal' so the problem is in the central unit.
  2. if the monitor does not display 'No signal' so the problem is in the monitor you have to replace it.
Dec 21, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My Dell Inspiron 530S beeps three times when powered up, the USB ports have no power and the monitor isn't getting a signal. Any suggestions?
Beeps during startup/POST means you have a hardware failure that is stoping the computer from starting up normal. 3 beeps means you have faulty RAM. You could trying removing a stick if u have more then 1 installed, however replacement is ideal. RAM is highly inexpensive and is a DIY project that would take less than 10 minutes to complete. However if your computer is under warranty I suggest calling dell and letting them deal with it.
Here is link to beep codes for future reference
Let me know if you need instructions on to swap out RAM, I would gladly assist, please rate
Nov 10, 2010 | Dell Inspiron 530 Desktop Computer
Pc turns on but screen says no signal
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card.
  • When the PC turn on there is any beep.
  • If no beep then your RAM is alright.
  • Problem in VGA Card.
Mar 15, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
No signal to monitor / Beeping
Listen to the pattern of beeps, or look at the back of the computer to see the pattern of the diagnostic lights ( 4 lights just under the keyboard/mouse connectors) and check out this site to see what they mean:
Beep Code Meanings
Diagnostic Light Meanings
May 29, 2009 | Dell OptiPlex 160L (160LMIN) PC Desktop
Computers & Internet Logo
175 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
