Question about Keurig B50 Coffee Maker
Pump doesn't seem to pull the water in to brew
  • dobrow1 Sep 11, 2010
    If the pump won't pull into the machine there is no way to get it to descale the machine
    How am I to put lemon juice through the machine if the pump won't pull the water through the coffee maker?
  • 10,515 Answers
There is a major design defect with all the newer Keurigs, including the B60 and the B70/B77. My understanding is that Keurig has redesigned the pump mechanism that extracts water from the reservoir and into the brewer (there's a second pump that forces the hot water through the K-cup, and it's not involved). They are now using a small DC motor and impeller pump, which is much quieter (to address complaints in many reviews) but the new design just doesn't work.
It appears that air gets into the system, and the new pump isn't strong enough to "self-prime" in this case. So the pump motor runs and runs without water going through it, and eventually turns itself off so it doesn't burn out (it should usually take only a few seconds to fill the internal tank). Many people think the problem centers around the 'check valve' in the base of the unit, just below where the clear reservoir seats itself: Theory is that the tiny pump can't pull hard enough to open the check valve to let water flow, especially when there's any air in the system.
I've had two B77 units already myself, and both have failed this way within only a few weeks. FWIW, the workaround I discovered is to turn the unit on, and lift up the water-filled reservoir about 1-2" as if you're removing it. Then jam it back down into place, hard and fast. Doing this injects just enough pressure into the system to open the check valve, and if the pump motor is running, you'll hear (and see) it immediately start transferring water from the reservoir to the chamber. You'll often have to do this between each cup you brew, and again when you first turn on the system.
There are hundreds of similar reports all over the Internet about this issue, and apparently no real solutions from Keurig yet (I don't even know if they're acknowledging the problem). Other symptoms include brewing half-filled cups of coffee, as others on this forum have reported.
I suggest everyone call Keurig's customer service and file complaints about this until they come up with a fix. Don't let them tell you it's a problem with your AC power or your hard water (they'll try excuses like those first). And until they redesign this, there's not much point in having them ship you a refurbished replacement for your brand-new machine, because chances are it will quickly fail just like your old one.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • 10,319 Answers
Add 3 ounces of Real Lemon Juice into it with a cup of water. It will descale the unit to operate again
No power to the air pump
Power board is defective and needs replacing
Jul 07, 2013 | Keurig Special Edition B60 Coffee Maker
My Keurig B66 will no longer pump water up to brew, I have had this less than 6 mos, what should I do?
it seems that it does not pump water in, after switching it to ON, it stays running for a few minutes then shuts OFF without even showing "READY TO BREW"..
Jan 02, 2010 | Keurig B100 Coffee Maker
My Jura Capresso coffee maker is "shorting" the coffee, delivering espresso-sized portions instead of larger volume coffee. The electronics seem to be malfunctioning.
The sieve in the brew unit is probably clogged, this means that it takes to long to push the water through the coffee. There is an automatic time-out on the pump that controls this. It also can be that your coffeeoutlet is clogged.
Try cleaning out any used coffeegrounds from the inside of the machine, use your finger up into the brew unit. If this doesn`t help, it needs service.
Sep 13, 2009 | Jura Capresso Impressa F9 Espresso Machine
Water gets hot but doesnt pull water to grounds
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
May 13, 2008 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Baby gaggia wont pump
The pump may only have lost its prime. To prime the pump:
Fill an ear syringe (available at most pharmacies) with water. Insert the business end of the syringe securely in the tube that normally takes up water from the reservoir. As you squeeze the syringe bulb, flip the brew switch on. If you see movement of water in the tube, and hear a change in the sound the pump is making, flip the brew switch off, remove the syringe, and put the tube back in the filled reservoir. Now flip the brew switch on, and see if the pump can draw water on its own. Repeat several times if necessary. If the pump still won't pull water, then it must be replaced.
www.espressosolamente.com
Apr 21, 2008 | Gaggia Baby Espresso Machine
Water flow
You will have to adjust your shot timing, and possibly your grind. To program the shot timing, hold the Brew Stop button until all of the brew lights come on; That means all of the buttons are ready to program. Next, pull some grind for your portafilter and push the button you want to program. For a single, you want to pull a 1 oz shot in about 15-20 seconds; longer for a double. When you push the button, the shot will start to pull; when the shot is complete, push the button again to set it. Then do the same for the next button. Each group needs to be programed separately. Holding the the Brew Stop button again will turn out the remaining lights and save your programming to that point. As to the grind, you want to have the grind fine enough to give you a quality shot in the right amount of time. Good Luck!
Oct 13, 2007 | Astra Mega II Espresso Machine
Keurig B50 Coffee Maker Logo
230 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
