Question about Refrigerators
Water is collecting in the bottom of fridge beneath the vege bins
  • 1,531 Answers
Normally this is caused by the evaporator drain being clogged with frozen water or other particles and needs to be cleaned.also need to make sure that the defroster is not on at the same time it is in a cooling mode
Posted on Sep 11, 2010
My LG refrigerator bottom vege bin keeps freezing the vegetables
Check the thermostat setting, clean the condenser (underneath and behind fridge) and make sure any fans/ vents are ok.
May 21, 2012 | LG Refrigerators
Water has collected and frozen at the bottom of the freezer compartment. From time to time I get small leaks on the floor beneath.
There is a drain tube from freezer/fridge and stops under the fridge and allows water to drip into an evaporator tray. The drain tube/hose can get blocked up, it is very common. Free up the tube and you will be good to go. Sometimes just snipping on the very bottom to make a larger drain hole works too.
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Water pooling at the bottom of kenmore fridge
I had a Kenmore fridge - about 20 years old when I replaced it this year. It used to do the exact same thing especially in warm/hot weather. What it is is the water from the freezer defrosting. There should be something on the back near the top, inside the fridge sticking out - a tiny little tray sticking out and it may also be part of supporting one of the shelves, I can't remember. Anyways, water from the defrost pools in there and is supposed to evaporate, but it gets clogged with gunk and the water spills out and runs down the back of the fridge down to the bottom. Get a pipe cleaner or something and poke it into this hole and clean out the pipe to the hole isn't blocked. This is all inside the fridge, not outside, on the back panel outside. That's the best I can do to describe the solution - it's an easy fix you can do yourself. Good luck!
Jan 01, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Fridge Leak
We fixed the leak by putting a pipe cleaner down the hole inside the fridge, at the back. This cleared the tube as it had gunk and grime blocking it. Now the water can run freely down the tube and into the drip tray which is at the back of the fridge above the motor.
Jun 12, 2009 | Fisher Refrigerators
F & P Fridge/Freezer Model N395B freezing under vege bins
While staying with a friend that had this problem we assaulted the fridge. Pulling everything we could apart. After finding this link http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517579%20%20Series%20R%20N308R,308XR,325TR,369BR,375TR,395BR,400HR,4.pdf which had a parts list similar to the fridge we had. Pulled out the Defrost timer paragon located next to the compressor. After giving it a good shake it started making ticking sounds again. It appears that it is semi-faulty in our case and had stopped working.
Dec 04, 2008 | Fisher and Paykel Active Smart E522B...
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
