Menu bar appears automatically in front of monitor and automatically uses it.
My SAMTRON monitor 56V is having a problem now..
The control menu of monitor settings which will appear
when the monitor control panel is pressed(Brightness,Contrast....) is coming frequently at my monitor without activation...
Now when the monitor is turned on, the control panel will come,and will not go even if we change the settings..
The control panel is switching between the CONTROL LOCK and UNLOCKED mode during each 5 seconds....So now I cant see anything on my screen
at the middle of the screen due to this overlaying settings panel.
I is giving the same effect as the Menu key is pressed in the panel..(exit,-,+,Menu).
This problem started some 2-3 months before..
Today I hav put some etylene cleaning solution through the gaps to clean from dust... still no change...
If somebody having a remedy please help me..
Posted on Sep 12, 2010
Monitor menu appears automatically
this problem is about menu buttons who is shown on front of monitor, change it/ take assistance a hardware engineer.
Aug 25, 2011 | Computers & Internet
I have compaq tft8020, from last 2 days i m facing problem. lcd is showing automatic"adjustment" between cable 1 or cable 2 with in 1 second.pc display is showing, but adjustment is continusely showing and...
mr farhanpk, When very strange stuff starts to appear on the screen of any older model ccfl -back-lit lcd display I would certainly suspect and investigate the monitors ac to dc internal power supply for BAD, SWOLLEN, LEAKY electrolytic filter capacitors. Check your pc with a "known-good" monitor to make certain it is not the pc causing the problem. 12fixlouie
Aug 07, 2010 | Compaq TFT8020 18.1" LCD Monitor
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
Aug 03, 2010 | E-Machines eMachines Desktop PC
OSD lockout, monitor menu appears and changes input automatically
the menu button might be jammed, try pressing it long and releaseing it, sometimes that happens to me
Feb 14, 2010 | HP vp17 Monitor
My monitor displaying OSD menu Automatically.......and monitor screen is also disturbed(as it shrink and its contrast will goes automatically at 100...and many more problems like this)
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]
Sep 10, 2009 | SAMTRON 55V 15" CRT Monitor
check buttons on front of monitor or display properties in windows
Aug 20, 2009 | Computers & Internet
Monitor problem
It seems that ur control panel on the monitor having some problem...U need to take it to service center....
Dec 02, 2008 | Computers & Internet
COMPAQ 7500 monitor, MenuBar/Brightness Bar, Keys not working
replace Menu buttons (Microswitches) and check 5v path
check dry points.
Oct 11, 2008 | Compaq 7500 17" CRT Monitor
Contrast problem
my monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem?
Jan 25, 2008 | IBM E54 (Pearl, White) 15 in.CRT...
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
