Question about Excalibur RS-310-EDP Remote Start Keyless Entry Dlx Map:58.50
Car cranks but will not start - Excalibur RS-310-EDP Remote Start Keyless Entry Dlx Map:58.50
  • 5,370 Answers
Most probably its a low fuel pressure related problem.Get the fuel pressure checked.If its low then this is faulty fuel pump and clogged fuel filter issue.the other possibilities are,-----
A car that cranks over but doesn't start, in many cases will be due to a bad fuel pump, a broken timing belt, an inoperative cam sensor or crank sensor. Also this problems are related to faulty spark plug. Check the spark at spark plugs when you start the car. Do you notice any spark. Actually you should see. If in case there is no spark then it's a spark plug problem. Also the coil pack gives power to spark plug. So check the voltage at coil pack. It will show 12 volt.If there is no voltage noticed at coil pack then its faulty coil pack that has to be replaced.If all the possible options checked out ok then check the car starter. The starter gets power from battery to start the care. If the starter is faulty then it will not let the car to start. Also check and confirm that there is fuel in the car. If it very low fuel then in some cases this causes the problem. Also check and confirm that fuel pump is functioning properly and the fuel filter is not clogged. One of the easiest ways to check for a fuel pump related problem is to spray a little starting fluid into the air intake while trying to start the car. If the car starts momentarily, then there's a good chance the fuel pump is not working or the car is out of gas. You can also listen for the fuel pump's humming sound when the key is first turned on. Also if a inoperative fuel pump is suspected, a good technician will always check to verify there is power and ground being supplied to the pump, to eliminate the possibility of a bad relay or electrical issue. Fuel pressure can be checked with a pressure gage and if there is pressure, pulse can be checked at the fuel injectors in several ways including the most common, with the use of noid lights. If the injectors don't have pulse the engine won't start. ---------- This troubleshooting tips will help you to solve the problem.Thanks.Helpmech.
Posted on Nov 12, 2010
It turns over but it wont start
Engine cranks but won't start. Troubleshooting tips
www.samarins.com/diagnose/index2.html
In this guide, we are going to look into no-start problems when the car engine cranks,but won't start. If your engine won't crank at all, check the first part No-start: ...‎Why a car won't start - ‎Crankshaft position sensor - ‎Check Engine light
Engine cranks but won't start - YouTube
? 8:03
https://www.youtube.com/watch?v=1L4nB2NdA0U
May 16, 2014 - Uploaded by jimthecarguy
2003 Ford Taurus 3.0 liter 24 valve no start cranks OK.You will not ... Car will not start trouble shooting guide, wont crank, wont turn over, etc.
Problem 5: Engine Cranks But won't Start
Jan 01, 2016 | Cars & Trucks
My husband just replaced my water pump on my 2000 Camry, now it cranks but won't start what happened?
car no start problem. - YouTube
? 6:11
https://www.youtube.com/watch?v=uaKQkHMgFSI
Mar 18, 2014 - Uploaded by LearningZone
Here is Toyota Camry 2000 model which is not starting. The car had come from ... Test an engine that cranks but won't start. - Duration: 1:54. by ...
www.samarins.com > For Car Owners
Few tips how to find a problem when the engine cranks but won't start: what is ... If your engine won't crank at all, check the first part No-start: Car won't crank. .... Now, Google "Passlock" and you will find a number of treads at various forums ... cause a problem where the engine cranks but won't start in some 1996-2000 ...
Oct 29, 2015 | Cars & Trucks
My 1989 Toyota cress I'd a will crank but won't start .
Fixing A Car That Cranks But Doesn't Start Up - YouTube
? 3:22
www.youtube.com/watch?v=064Ilsz8Fzg
Mar 30, 2010 - Uploaded by Scotty Kilmer
Fixing A Car That Cranks But Doesn't Start Up ... for the last 46 years and counting, shows how to fix a car that cranks over but will not start up. ... Engine cranks but won't start - Duration: 8:03. by jimthecarguy 477,267 views.
Test an engine that cranks but won't start. - YouTube
? 1:54
www.youtube.com/watch?v=weidkoI7clE
Aug 24, 2011 - Uploaded by CheckMyEngineLight
I have a 98 Jeep Grand Cherokee and it will crank but won't stay crunk. .... Try this if it cranks perfectly but wont start : Camshaft Position Sensor ...
Oct 27, 2015 | Toyota Cars & Trucks
1998 ford couier ute wont start
it must crank fast or no car starts.
mine push starts and gravity starts.
does crank,,,
look at crank shaft of car (front pulley) is it spinning fast as person 2 cranks, yes, then it is cranking and must be fast and robust.
is it?
Mar 25, 2015 | Ford Cars & Trucks
Will not start
is this this s DIY question or ? just a request for wild guessing.
Ill assume its a real DIY. ? do tell.
what is a jumper box to house. ?????????????????
first off, you need to say,
it cranks robustly but does not start or not.
does it crank? if yes, why buy a starter?
no car starts unless cranked. (mine push starts and gravity starts)
but I bet yours is a A/T tranny , automatic.?
so does it crank.?
lets pretend, it cranks perfectly.
and really is a no start (confusing your replacing a starter )
this jeep , like most from 1993 have the ASD relay.
THE ASD relay must close to start the engine.
The ASD relay must close, and if spark , and up to 7 other things
are good, then it will stay closed, if not it drops out. KILLING starts.
that is what it does, so watch the ASD while cranking, what does it do>???????????
http://www.fixkick.com/Jeeps/ASD.html
now I will do NO CRANK.
and the funny house box thing, (a battery charger? or what i cant guess)
no cranks are caused.
By bad shifter, switch.
this is called the key line.
so i hot wire the starter solenoid, (remove tiny wire first to it)
ask how to do this.... its not hard. (mostly but some cars have shields making it harder today)
and it dont crank ! NOW? , then bad battery,starter bad, cables or seized engine. (turn engine by hand ,ok? to spin? by hand?)
and it does crank. then bad key line is reason.
easy huh? just one hot wire step and bam, problem cut in half.
i then try to crank in neutral, bam it cranks. and starts.
bad PRNLD switch.
or i just wiggle the shifter, bam, it cranks
or i wiggle the key switch funny in crank position and bam it cranks
bad key switch.
last, pretend the starter fails the hot wire above.
i hit it with a hammer, bam it cranks now.
we can do all that with a voltmeter easy,
ask.
http://www.fixkick.com/nocrank.html
see hot to solve no cranks on most cars.
other simular failures.
battery dies after parked.?
charge light (dash) on , driving? or idling, bingo, dead battery.
one more , car cranks but will not start for longer than 2 seconds
ASD action
but you failed to notice the Immobilizer lamp glowing wrongly.
my last answer. the funny house thing is a battery charger
and if you leave it charging long enough car cranks.
bingo?.?????
if yes, then the battery is DEAD and is DISCHARGED.
it discharged because you or something is left running, in car.
see phantom drains here.
the reason the car jump failed is you didnt give it enough time.
a very bad car battery can swamp the donor cars power source.
(and easy with cheap jumper cables.)
here is what you did wrong.
car is rested, it wont crank
you open the hood.
and check the batteryvoltage with a volt meter.
it reads 12.6vdc rested. good, it should crank ok, (but my not)
or it reads 12v, its discharged, so charge it to 12.6v and try again.
http://www.fixkick.com/drain/drain.html
  1. won't crank?
  2. battery discharges overnight.?
  3. won't start but cranks ok.?
  4. charge light stuck on.? running.?
which?
Apr 05, 2014 | Jeep Compass Cars & Trucks
My vehicle has a hard time starting 2 all time
hard to crank over at full speed, starter speed)
or cranks perfecty but will not start.
no crank, weak cranking
or not starter.
no car can start if it cant crank.
Oct 23, 2013 | Toyota 4Runner Cars & Trucks
Refuse to start, who much will it cost me to buy another one?
another what?
NO CRANK or NO START
no car starts unless cranked fast. or pushstarted (stick) or jumper cable cranked.)
if it dont crank
1: check all fuses.
2: try jumper cable start, does it crank now (stater makes noise and engine crank shaft spins(eyes see that)
Aug 05, 2013 | Honda CR-V Cars & Trucks
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
Car wont crank 1994 plymouth acclaim
Not sure what yor experiencing . Do you have crank no start or no crank no start? No crank no start is battery and cables issue. Crank no start is ignition , plugs, and fuel.
May 28, 2009 | 1991 Plymouth Acclaim
Excalibur RS-310-EDP Remote Start Keyless Entry Dlx Map:58.50 Logo
235 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
andy148814
Level 1 Expert
Rocguy
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
