Question about Bosch Dishwashers
My Bosch SHX46L dishwasher barely puts out water when running any wash cycle. Drain is clean and it has no problem draining water. Also a small grinding or wining noise that I did not notice before.
  • 1,531 Answers
If there is enough water in the bottom of the unit then you main wash motor needs to be replaced. if there is not enough water then you may need to replace the water valve.also check the main water line for kinks or restricted water flow
Posted on Sep 11, 2010
Bosch Dishwasher won't drain.
Is there a hi-loop in the drain line, is water siphoning back in after a drain cycle?
Jul 08, 2016 | Bosch Dishwashers
My 7 year old Bosch dishwasher (SHE56C) started to run for hours when set to wash on any cycle.
Do you hear it go into the drain cycle that is do you hear the drain pump run at some stage. What happens in the rinse program (short cycle)? It is likely the thermostat is not working or the water temperature is too low due to heater problems.
Apr 19, 2013 | Bosch Dishwashers
Dishwasher will not drain
check the water pump this could be blocked
Apr 20, 2010 | Bosch Integra® 500 SHX46L Built-in...
Will not drain in drain cycle
If you can hear the pump attempting to pump the water out, disconnect the dishwasher drain hose and place a bucket underneath it and run the drain cycle again. This should clear any clogs along the drain line and prove that your pump works. While you've got it disconnected, remove the air gap vent and clean it. A small, but large enough amout of debris can be blocking the flow of water from the dishwasher's drain hose to the garbage disposal or drain pipe. The air vent has a small cap at the top that can be removed to make cleaning easier by simply flushing it with water.
Mar 20, 2010 | Bosch SHU9915UC Dishwasher
DOES NOT DRAIN
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 15, 2009 | Bosch Integra® 500 SHX46L Built-in...
Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
May 28, 2009 | Bosch SHU3036UC Dishwasher
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Dishwashers Logo
51 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
