Question about Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer
Faxing out with my Canon MX870 - always get printed report at end of attempt saying "line busy." Phone line is working (plugged landline into wall jack to test). Called fax # to verify it was NOT busy. Phone cord tested and works fine. Only tried faxing out twice since i bought it and neither time worked. First time had someone standing next to their fax while I was trying to send it -no success. Fax scans fine,dials out fine,beeps with the rings but never an "answer" on the other end. I don't kno what else to try. Ron
  • 3422 Answers
SOURCE: no dial tone
hi,
Buisy signal indicates that there is problem with your connection.Please try unpluging all the cable connections and wait for 30min and then plug them all back and make sure that all the cables are connected firmly.
Goodluck,
Please dont forget to rate the solution.
Posted on Apr 11, 2008
SOURCE: faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
Posted on Jun 17, 2008
colliewob
  • 781 Answers
SOURCE: can't send or receive faxes on my Canon MF 6550
have you just changed over to dsl from standard modem when i had this problem it was because to fax out/in i needed a standard 56kb modem to do so as dsl does not go through the normal phone lines and cannot connect to standard phones which is what fax machines are on
Posted on Jul 28, 2008
SOURCE: trouble faxing
how do i send a fax
Posted on Nov 25, 2008
  • 7 Answers
SOURCE: Cannot receive faxes on Canon Pixma MX870, but can send faxes
I was searching for an answer to this to make sure my new MX870 is correctly set to receive faxes. Here's one answer I came across:
First set Tel-Priority, turn off incoming ring, turn on manual/auto switch, then check how many seconds it takes for your answering machine to come on, and set it a couple of seconds after that. This should do the trick.
Posted on Oct 03, 2010
My landline phone is not working?
Remove all phones from the wall jacks. Plug in one standard telephone, preferably not hands free. If it works, plug each one in testing as you go.
If the first phone doesn't work, phone your phone provider and report the fault. They will test the line remotely and send out an engineer if needed.
Jan 29, 2018 | Lands Phones
Fax install
Plug one end of the cord into the wall jack for the phone, and the other end into the machine in the jack labeled LINE usually on the back or side of the machine toward the back. Let me know if you need further assistance.
Apr 01, 2009 | Canon imageCLASS D761 Copier
Problems with faxing
Plug the phone cord into the LINE port
Nov 25, 2008 | Canon Laser Class 810 Plain Paper Fax
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Can't fax from Canon Pixma MX310
I just got this MX310, and absolutely can't get the machine to fax a document. I know I have it connected properly, but keep getting an "incomplete transmission" report. There is NOTHING in the instructions about faxing at all! HELP! Thanks!
Aug 21, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
If the supplied phone cord is not long enough, you can extend it. For
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
Not connecting to fax out
Do you have a DSL or other digital phone line?
Jul 10, 2008 | Brother IntelliFax-2820 Laser Fax
Canon m830 faxing problems
Do you have a filter on the line? Also make sure the phone line from the wall is plugged into the jack in the back of the machine marked "line" and not "phone"
Dec 06, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Can't receive a fax
Make sure the phone cord from the wall is plugged into the port in the back of the machine labeled "line" and NOT "phone"
Aug 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon PIXMA MX870 Wireless Office All-in-One InkJet Printer Logo
648 people viewed this question
old marine
old marine
