Question about Optics
I have had RedHead 7x - 21x binoculars for about 4 years now and I have ran into a problem. When I look through them I am seeing double. I have adjusted the focus and changed the distance that I am holding the binoculars from my eyes and nothing seems to make a difference. Is there something wrong with them? Can they be fixed? Where would be the best place for survice?
    Brigadier General:
  • 3,006 Answers
You have the classic signs of the most common binocular fault: a bent or broken eyepiece carrier yoke.
The cause is usually due to the binos being dropped or stored standing on the eyepieces. The only cure is a replacement yoke, but the repair is rarely cost-effective unless the binos are really expensive and top-quality models. Although most RedHead models aren't cheap, they certainly don't fall into the realistically repairable bracket.
Broken/bent yokes cannot be repaired: If bent, then it's near-impossible to unbend them accurately enough and in any case the process will always either break the yoke or will severely weaken it. Broken yokes cannot be glued together as the contact point is just too tiny for the loads it carries, and as it usually bends before breaking you'd simply end up with a bent yoke afterwards even if you could glue them.
Posted on Sep 12, 2010
Do you have a manual for Zeiss NVA 740 binoculars
No ... is there something you don't understand about you looking into the small end of the binocular ? Your not going to fix them nor make any adjustments. other than adjust them for you eyes. and that's the same for most all brands.
Sep 01, 2014 | Zeiss Carl Ddr Nva 7x 40 Binoculars,...
I see double image unless I take the lens as close as the binoculars can go
thats how binoculars are. Yours in this case is really strong. the closer you are to something, looking at it, the more magiflyed you going to be. try view things far a distance, really far away. no more double right?
Everything you need to know to become an expert:
on this website: http://www.chuckhawks.com/binocular_basics.htm
It is surprising how many people do not know how to focus binoculars correctly. There are two common focusing systems used in binoculars.
The first is individual eyepiece focus. This system is simple to understand, and easy to manufacture. It also lends itself well to sealed optical tubes, and thus is usually the focusing system used for waterproof binoculars. Individual eyepiece focus means that to focus the binoculars to your eyes, you simply focus the left eyepiece to your left eye and the right eyepiece to your right eye. There is no centrally located focusing mechanism. It is done like this. Look at something in the distance. Close the right eye (or cover the front of the right binocular), and focus the left eyepiece to your left eye. Close the left eye (or cover the front of the left binocular), and focus the right eyepiece to your right eye. You are finished, until you need to look at something at a different distance, in which case you need to repeat the process.
Because individual eyepiece focus is time-consuming, center focus is more common. Unfortunately, very few people understand how to correctly use center focus binoculars. Here is how it is done. Aim your binoculars at something in the distance. Close the right eye (or cover the front of the right tube), and focus the left side of the binocular to your left eye using the center focus control, which is concentric with the pivot shaft between the binoculars. (Note: the left eyepiece itself does not focus on center focus binoculars.) Next, close your left eye (or cover the front of the left tube), and focus the right eyepiece to your right eye. DO NOT touch the center focus control while you are focusing the right eyepiece to your right eye. Now you are finished. What you have just done is adjust the binoculars for your individual eyes. (Practically everybody's left and right eyes are different.) From now on, you only need to adjust the center focus control when you look at things at different distances. Center focus is faster and easier to use than individual eyepiece focus, once you have initially set the binoculars for your eyes.
Binoculars are commonly described by using a pair of numbers, as in "7x50" or "8x25." The first of these numbers refers to the magnification offered by the binocular. Magnification is why most people buy a pair of binoculars. In the examples above, "7x" means the binocular makes whatever you look at appear seven times closer than it does to the unaided human eye. "8x" means the binocular makes whatever you look at eight times closer than the unaided human eye. "10x" makes things look ten times closer, and so on. The first number used to describe binoculars always refers to their magnification. Common binocular magnifications are 6x, 7x, 8x, 9x, and 10x.
There are also variable power (zoom) binoculars, such as 7-21x50. These almost always perform much better at the low power setting than they do at the higher settings. This is natural, since the front objective cannot enlarge to let in more light as the power is increased, so the view gets dimmer. At 7x, the 50mm front objective provides a 7.1mm exit pupil, but at 21x, the same front objective provides only a 2.38mm exit pupil. Also, the optical quality of a zoom binocular at any given power is inferior to that of a fixed power binocular of that power. In general, zoom binoculars are not the bargain they seem to be.
Remember that everything (including movement) is magnified when you look through a pair of binoculars, especially your own shakes and tremors. So the higher the power, the harder it seems to hold the binoculars steady. 6, 7, or 8 power binoculars are easier for most people, even those with very steady hands, to hold reasonably still. The higher powers sound like a good deal, but often result in jiggly, blurred views. This is why 7x binoculars are chosen by so many experts, including the military.
Power affects brightness. Other things being equal, the higher the power, the dimmer the view. And power also affects the field of view of the binoculars. Again, everything being equal, the higher the power, the smaller the field of view. So, as you can see, power must be balanced against other desirable characteristics when choosing binoculars.
May 09, 2011 | Bushnell 240842 Binocular
Have lost rubber eye piece off Steiner binoculars. How can I get a replacement. They are a compact pair taht we have taken on holiday each year. Name on binoculars says that they are 8 x 22...
need the rubber eye piece for 7x 50 jason/empire binoculars and also the one steel rim that goes under the eyepiece. I would appreciate any help that you could give me. thanks
Mar 29, 2011 | SteinerPredator8x22 Binoculars
Minolta Standard Zoom 7x to 15x x35 binoculars
yes it is fixable its the inner lenses coming loos and they will need to be fully striped down and cleaned the body air blasted out and then all lubed and put back together before being re-gased,,,standerd overhall job,,,pricy too,,,
Mar 03, 2010 | Optics
Can i replace zoom cog on my 7.15 x 35 binoculers around 15 years
Sure the cog can be replaced, but it's best done by a service technician as you may lose zoom registration between both sides of the binocular if you try to do it yourself. Then you will end up with one side at 7X and the other at 10X and a big headache to boot.
Feb 04, 2010 | Samsung Optics
Seeing double in 12x50 powerview binoculars. I don't see double in other binoculars.
The optics have shifted. Either the front objective housing have been knocked sideways in the body thread, or the intermal prisms have moved. If they are new binoculars take them back to the place of purchase and ask if they can repair them or know of a repair agent.
Dec 25, 2009 | Bushnell Powerview 13-1250 (12x50)...
Value of the model 172 Jason Binoculars
I'm sorry to say this. Not much. Maybe 30 dollars US on a good day on the auction site if the binoculars are in great condition. Zoom binoculars are not known for their quality optics. Jason binoculars have a small collectable quality in a niche market for old Japanese optics. Just to have not for their optics. Non zoom older Jasons are worth a small amount more.
Aug 23, 2009 | Nikon Superior E Binocular
I just got an old set of kalimar Model K7070 Binoculars ( 7X-15X35)from my father. They seem to have some type of water drop marks in the left lens. Are these worth trying to repair. I do not know what he...
The water drop marks you are seeing may be seperation of the lens coating. Most binoculars after WW2 have some form of anti-relective coating on the lens. This is applied to the glass surfaces in varying degress by various manufacturers. Its intended purpose is to reduce the amount of light that is reflected off the glass so that the image you see is brighter. Your windows at home that aren't covered actually don;t allow all of the light to come through!
What they all have in common is that the coating is applied onto the glass. Over time like anything that is stuck on or painted it can begin to peel off.
You could try asking a repair place if they caqn replace the lens but most likely they would need to change both so that they have the same coating. The binoculars are worth more for sentimental value than the cost of repair as a similar replacement set would cost as much. Zoom binoculars are not known for their optical quality. Often this 'watermark' effect doesn not interfere with the view. If your sentiments say fix them regardless do so. If not hold onto them as a keep sake.
Aug 01, 2009 | Optics
Report a bug
the exact equation is
15x^2 - 21x - 18
=3(5x^2 - 7x - 6)
=3{5x^2 -(10-3)x -6 }
=3{5x^2 - 10x + 3x -6}
=3{5x(x - 2) + 3(x-2)}
=3(x-2)(5x+3) these are the factors
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
9899780221
Oct 16, 2008 | SoftMath Algebrator - Algebra Homework...
BLINKING LIGHTS ON fURNACE
had same problem, first you need to find the location of ignitor double black wires from plug on board and flame sensor.single red wire. 4 red flashes means ground fault, I removed ignitor, cleaned with some scothchbrite, cleaned around screw holes(2) to reestablish ground, I even ran a wire from one of the mounting screws to a ground elsewhere. then I went on to the flame sensor witch will give you flashing yellow light. single red wire to sensor that has one screw holding in. Remove sensor carefully and do the same as the ignitor, clean with scothbrite. I did this a year ago and is still going!
Jan 21, 2008 | Dishwashers
Optics Logo
141 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
