Question about Whirlpool GHW9400 Front Load Washer
My whirlpool WFC7500V shows F-22 code when in cleaning cycle
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Duet HT code F22
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Whirlpool front load washer
1. Unplug washer.
(courtesy JSRock)
Posted on Dec 22, 2010
Daniel S
  • 4323 Answers
SOURCE: Whirlpool duet front loading machine
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Aug 04, 2011
What does Lc mean on my Whirlpool frontload washer?
lock
LoC or LC - Whirlpool Home Appliances
producthelp.whirlpool.com/Troubleshooting...Front_Load_Washers/.../LoC_or_LCApr 22, 2017 - If you try to push buttons, you may see the code "LoC" or "LC" ... For each second CONTROL LOCK is held down, the display will count ... You may still touch START to pause the cycle, or touch POWER to turn off the washer.
What does Lc mean on my Whirlpool front load washer Google Search
Jun 24, 2017 | Whirlpool Washing Machines
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
I need help with my Duet washer
it sounds like an electronic problem with the board.
Nov 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading machine stops before the final spin cycle, leaving loads full of water. Prior to stopping the display shows 18 to 22 minutes left in the cycle, but suddenly stops. There is no...
Hi
Daniel
Aug 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Starts cycle with add a garment light on. after few min f-21 code on with all lights flashs .cleaned drain pump filter. wirlpool duet sport model #wfw8300swd
Whirlpool F21 (and 16, 18, 20 and 22) states 'control unit failure'. Could be poor connections but requires a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 16, 2011 | Whirlpool WFW8300SW
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Jul 29, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
ERROR CODE E1 MODLE #GGW9200LW O
E1 error code is for the thermistor, try cleaning off the bottom of the thermistor, (sometimes tacky lint will coat them), if that doesn't help, just replace the thermistor.
Sep 17, 2008 | Whirlpool GGW9250PL Gas Dryer
Whirlpool GHW9400 Front Load Washer Logo
222 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
