Question about Moen 7065ORB Vestige Single-Handle Kitchen Faucet with Side Spray Oil Rubbe...
I have a Moen Faucet I believe a 7065 with a separate spout, lever handle and side spray. I take off the cap and go to remove the Allen screw but it will not turn or come out. My faucet has the water trickling out and I think needs to be cleaned
  • 377 Answers
If the allen screw will not turn I would put an allen wrench into it and lightly tap it a few times with a hammer, the smaller the better. If the allen screw is stripped I would get a set of easy outs from the Home Depot or other store and use the smallest one to ease the screw out. An easy out works in reverse to the threads in order to get the screw to back out of the hole.
Posted on Sep 12, 2010
How can you remove a 7560w spray head?
  • Take out the plug button on the front side of the faucet handle and loosen the set screw with your Allen wrench, then pull off the handle. Remove the domed cap underneath the handle by unscrewing it.
  • Take off the entire spout by removing the mounting hardware under the base and lifting the spout up and off the faucet. The hose will be attached underneath the counter. Once you unscrew the connector, the spray head can be removed.
Sep 09, 2014 | Moen 7560W Extensa Glacier Lever Handle...
How to tighten swivel spout of moen kitchen faucet
pop the cover off the top of the spout tighten the screw underneath and replace the cap.
May 11, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Cannot remove handle. Allen wrench receiver is stripped. Are there any other options? Thanks!
There is a home cleaning product called the The Works which will loosen the corrosion around the screw. Then use a screw extractor tool. You can find one at most hardware stores and home centers.
Another solution would be to call Moen Customer Support and ask for a new handle and repair parts for free. The faucet should have a lifetime warranty. When you have the new faucet parts in hand, literally cut the handle off the faucet with a hacksaw or drill the screw out to remove the handle.
Sep 07, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Don't know model of my faucet but it is designed similarly--faucet is separate from spout. The handle doesn't stay in position unless it is on full force. Otherwise, it shuts off.
Take it off (the handle) and tighten the bolt underneath it that adjusts the pressure. My husband is a plumber and he said it's a simple fix. Hope this helps. To get the handle off- take the cover off and there's a screw underneath it- take it off and then tighten bolt
Dec 31, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
The handle is loose. It's a single lever control. The mechanism the level connects to still works fine. No leaks, but the handle is now quite wobbly, and I don't know how to tighten it. Do I pry out that...
Remove the plastic red and blue insert or what ever color yours is under the handle in the front. Tighten the set screw with an allen wrench. Be careful not to over tighten or the screw will break off.
Dec 27, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
My moen single lever faucet is loose, how do I tighten it?
On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
Nov 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 87135c - cant take apart
On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
Oct 03, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Can not figure out how to take it apart to replace leakey gasket
there is an allen key in the front of the handle.may be under where the hot and cold indicator is take that off and look to see if there is a hole.if so use an allen key to remove.
Jun 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 7065ORB Vestige Single-Handle Kitchen Faucet with Side Spray Oil Rubbe... Logo
360 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
