Question about Brother MFC-7340 All-In-One Laser Printer
I have the MCF 7340. I am getting a message - End of Drum Soon. So, I bought a new drum ($120) and installed it. Now it says Drum end. and won't print. Ive turned the machine on and off several times, re-insetred the drum and toner, taken toner cartridge out and re-installed and repeated these steps several times not, but still get the End of Drom message. is ther something that I must manually reset to fix this? David
If you open the front cover of your printer where you install the toner cartridge and press the "Clear/Back" button with it open, an option comes up on your LCD Display that says "Replace Drum?" press 1 to reset it. That should fix your problem!
Posted on Sep 26, 2010
Testimonial: "That worked!!! Thank you very much. "
  • 2 more comments
  • aliduin Sep 26, 2010
    Literally JUST fixed this problem. Had this drum end soon message for far too long.
  • mapsypam Jan 03, 2011
    Yay!!! THANK YOU SO MUCH! Fixed it in 2 minutes!
  • Loved1 Jan 11, 2011
    I brought a new drum when prompted by the printer, even though print quality was still perfect!! Decided to check internet and found your solution. It really works. Thanks a lot!!!
  • djemanon Aug 08, 2011
    Did what you said. Brilliant! Thank you.
Toner life end
Posted on Nov 28, 2012
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
Drum end soon again
My MFC-7420 began to display the message "Drum end soon" so I quickly went out and purchased a new drum. But I decided not to install it until I needed to. Because what does "drum end soon" mean? I thought it would mean that the print quality would deteriorate enough that I would notice the problem. So I continued to replace toner as needed, and pushed the blue cleaning thing down the wire regularly. This went on for over 3 years until *finally* I started having regular print job production problems. I replaced the drum, and the problems were solved. So,my advice is be prepared, but don't replace the drum until you have to -- the message means very little.
Mar 18, 2014 | Brother MFC-7340 All-In-One Laser Printer
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Drum end soon Brother DCP-7030
each replacable part has its own life of rotation, heat conversion ect. may be the life cycle of the drum reached to end. you need to replace the drum assembly.
Sep 22, 2011 | Brother MFC-7340 All-In-One Laser Printer
I was getting drum error message so I installed a new drum and toner. I am still getting drum error message. Please advise.
Did you "tell" the machine that you have installed a new drum? You have to confirm that the drum has been replaced, so the unit can reset it's usage counter and work happily.
Go to the link below, it explains the whole procedure, including the confirmation at the end.
Remove the drum again, reinstall same one and confirm as per the instructions.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000054/faq000154_039.html?reg=us&c=us&lang=en&prod=mfc7340_us_as&Cat=7
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Aug 08, 2011 | Brother MFC-7340 All-In-One Laser Printer
Drum end soon
Sounds like you need to replace the drum unit soon. Here is a new one that you can buy that is compatible with your printer: http://www.amazon.com/Brother-DR360-DR-360-Drum-Unit/dp/B001QTY5QE/ref=sr_1_9?s=office-products&ie=UTF8&qid=1305153837&sr=1-9.
May 11, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have replaced the drum but still get a message that the drum life will end soon.
Open the front cover and press clear/back buttom
then press start
finally, press 00, then the screen will show accepted.
after that, you will be good to go.
Jan 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
I installed a new drum, but I'm still getting the drum error message?
To reset the drum counter on the 7340 series press Clear/Back.
Confirm you are installing a new drum by pressing 1.
When the LCD shows Accepted, close the front cover.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Brother MFC-7340 All-In-One Laser Printer
Drum en soon MFC 7340
The drum counter counts to 15000 then says replace drum soon. Just open the front door and press options. Select yes.
Feb 03, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-7340 All-In-One Laser Printer Logo
3,412 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
