Question about Sport & Outdoor - Others
We were given a trampoline and had to take it apart when we moved and now we are not able to get it connect and set back up. We do not have instructions due to it being given to us and I am unsure of the model or how old it may be. Can you help me with how to get it set up?
  • 429 Answers
Put the legs together first, then attach the spring 180 degrees away from each other.
Posted on Sep 12, 2010
Parts for 6.5 Ft Funtek USA trampoline
Hi ,
We require a new net for this 12-14ft trampoline?
How much and can you supply these for the funtek trampoline?
Kinda regards
Cian
0416559159
Sep 03, 2014 | Funtek USA Funtek Trampoline and Enclosure...
Tip
Trampoline safety tips
According to the American Association of Orthopedic Surgeons
there are over 300,000 trampoline related injuries every year in the United
States. Many of these accidents are
caused by carelessness and a large percentage can be avoided with a few simple
precautions.
Buy padding to cover the springs, hooks and
frame of the trampoline; look for pads that are of a contrasting color to the
mat of the trampoline
Use something to cushion the surrounding area of
the trampoline - as well as underneath
Do not allow any children under the age of 6 to
jump on the trampoline
Institute a "one-at-a-time" rule for jumping
Ensure children are supervised at all times
Set up your trampoline away from structures,
trees or other play areas
Take a moment to inspect the trampoline prior to
every use
Remember, you can never be too safe when dealing with a
trampoline. Use these basic prevention
methods and talk with your children about exercising caution when jumping on
the trampoline.
on Aug 28, 2012 | Sport & Outdoor - Others
Trampoline Set Up Instructions
Connect all the poles together in a circle and atach teh trampoline mat to the circle.
Sep 13, 2013 | Sport & Outdoor - Others
I want to buy some outdoor play equipment for our 3 children, what do you recommend?
You could put in a sandbox. I live in a small garden apartment, so I don't have that much room. But if you have a big enough yard, I'm sure they'd love a swing set or a trampoline .
Jan 17, 2013 | Toys
What is the correct posture when jumping on a trampoline? I use mine a lot and have started to get backache.
Here are a few tips for good posture when using a trampoline. 1. Bend your knees when you jump. 2. If you put your hands up or out, bring them back to your side when you land. 3. Try and keep your body straight when you jump. 4. This is the basic technique. Once you get good at this, you can move on to exercising and tricks.
Aug 20, 2012 | Sport & Outdoor - Others
How big a trampoline should I buy?
What trampoline to buy depends on lots of variables. The , age and weight of the users are the main factors along with the amount of space you have to put the trampoline. But my advice is also to think to the future a bit. We bought a trampoline for our younger kids and they grew out of it really fast and we had to sell it. I came across a great breakdown of trampoline s that you should take a look at on the trampoline web and warehouse site. http://www.trampolinewebandwarehouse.com/what--trampoline
Is it ok to set up a trampoline on concrete?
Grass is preferred, however if you don't have the space for it, then you may set your trampoline on concrete. I highly recommend placing rubber bases under your trampoline to prevent it from moving while jumpers are enjoying themselves.
Jul 31, 2012 | Sport & Outdoor - Others
Are trampolines safe?
Trampolines are the most dangerous outside toy. Over half of all trampoline injuries result in leg or ankle sprains. There should always be supervision given while using trampolines. While they can be a lot of fun, they can also be very dangerous.
Jul 09, 2012 | Sport & Outdoor - Others
How to take a household trampoline apart
When I assembled my 14ft trampoline a few weeks ago the instruction were to attach springs at the 12 and 6 oclock positions then 3 and 9, then symetrically around the perimeter. Disassembly would be the reverse. Start by removing the spring at 12 then 6 oclock, then 3 then 9 oclock. You will always remove the spring 180 degrees away from the last spring removed. This means you'll be running around the trampoline many times but I think the idea is to remove tension evenly so that the mat isn't damaged. Once the springs and mat are removed I expect the frame will easily disassemble. My framo was like curved piping that fit together and is only held in place by spring tension. Hope this helps.
Jun 13, 2010 | Trampolines BQC1620
Trampoline net
Hope this helps. The trampoline net will either have a sleeve for flexible poles to form a ring at the top or there will be at least four obvious "loops" to hang from the poles. Then you need to sew the net to secure it to the mat/trampoline itself with rope. A good idea to buy new rope to do this as it wears with use. I have replaced my securing rope with "tie-down" rope from the sporting good department. The soft nylon kind seems to wear better. To sew: use a good knot to secure it to the underside of the trampoline (spring/Loop) then simple go through the net at the bottom skip a few holes come back through the net and go down around the bottom of a spring hold. repeat all the way around.
Apr 05, 2009 | Trampolines BQC1620
Sport & Outdoor - Others Logo
175 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
