Question about Toshiba Computers & Internet
In device manager there is yellow sign on PCI simple communications controller. How to update. I coonect headphone but still speakers of laptop giving sound
  • 57 Answers
Hi!
When you see PCI Simpple communications controller, it normally points to the built in dial up modem on a laptop.. You can download the modem driver from toshiba suuport site..
Hope it helps.! :D
Posted on Sep 11, 2010
Pci simple communication controller is missing
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 05, 2011 | Computers & Internet
In my computer -- properties-- hardware -- device manager -- PCI SIMPLE COMMUNICATION CONTROLLER IS SHOWING QUESTION MARK- DRIVER IS MISSING. MECHINE IS COMPAQ
ports(com&lpt)right click update driver hope this helps don
Mar 09, 2011 | Compaq Computers & Internet
Installing win 7 there is a device "simple PCI communications controller " and I can't find the driver.Thanks.
this device is probably just the internal dial-up modem of your PC, you can update the driver by going to MY COMPUTER > PROPERTIES> DEVICE MANAGER. Right-click on the PCI controller and select UPDATE DRIVER (only if you are online)
Oct 20, 2010 | Computers & Internet
PCI simple communication controller not installed.
First u have to install Microsoft Universal Audio Architecture .... that is UAA. then check in the device manager that is under system devices "pci bus" has excl. sign (i.e. ! ). Delete the pci bus device with exlc. sign. and press the button in the upper side of this window "scan for new hardware" it will automatically install the pci bus device and ur sound comes...
Jun 29, 2010 | Intel D845GVSR Motherboard
My pc shows yellow color in device manager pci
first of all right click on the yellow shield you will get a pop out menu choose update driver if that not help then you have to reinstall your hardware
May 14, 2010 | Gigabyte GA-7VA Motherboard
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
Pci simple communications controller
i cannot get the sound from the TV tunercard as the PCI simple communications controller in the device manager is showing yellow question mark
Feb 21, 2008 | EliteGroup 741GX-M Motherboard
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Computers & Internet Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
