Manual for LG Direct Drive WM-14225FD - Washing Machines
SOURCE: lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Posted on Aug 12, 2008
  • 38 Answers
SOURCE: LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Posted on Mar 14, 2009
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
  • 2468 Answers
SOURCE: what causes an lg direct drive not to spin
your tub needs to be totally empty of water first,if it is then open the top cover and run the diagnostics on the unit,if this fails then the control board is defective
Posted on May 29, 2010
SOURCE: LG WM-14225FD - making bad
it will be your pump that circulates the water. i have had mine replaced four times during its 6 year life! its common, not to be confused with the drain pump.
Posted on Sep 22, 2010
User manual for lg direct drive model wm-16341fd
model number doesn't exist please check again
Jul 13, 2016 | LG Washing Machines
Can I get an on line manual for model # WM-2233HW LG front load washer
Yes, LG has the user's manual for the WM-2233HW on the product site. Click on the Support tab here: http://www.lg.com/us/appliances/washers/LG-WM2233HW.jsp . The link to the manual is on the right side of the page. The manual is in a pdf so you will need Adobe Reader or a similar program to read the file. The direct link appears to be http://www.lg.com/common/product/support.jsp?localeCd=US&productId=WM2233HW&uri=/us/appliances/washers/LG-WM2233HW.jsp&categoryIdCms=2# . If this link doesn't work, please start at the first link I provided.
I hope this helps.
Oct 02, 2011 | LG WM-2277HW Front Load Washer
Looking for lg direct drive service manual wm-12220-fd - thankyou
you can go to (appliancerepairplanet.vstore.ca to get a sevice manual on it
Dec 08, 2010 | Washing Machines
LG WM-14225FD - making bad grinding type noise when in use
Aug 06, 2010 | LG Washing Machines
What causes an lg direct drive not to spin
May 29, 2010 | LG WM-2277HW Front Load Washer
My lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Dec 22, 2009 | Washing Machines
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Lg intellowasher DD 7.5kg WM14225FD error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Oct 01, 2008 | Washing Machines
Lg wm-14445fds direct drive 8kg washing machine manual
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
380 people viewed this question
Top Washing Machines Experts
