Question about Desa International 100089 06 Electric Chain Saw
Dear Sir, My name is Ronald Schoof and I have a problem with a chainsaw. The plastic drive gear teeth are worn beyond functional use of a Remington chainsaw 1450 Model 100 271-01 Type EL 4 I live in Spain and would like to know where I can buy this spare part. Is it possible that you could give me a link of where I can download the parts of this chainsaw. Regarts, Ronald Schoof
SOURCE: Poulan Pro Clutch Removal
Yes there is a special tool to engage on the clutch. You can get it from the Poulan web site - I think it is part number 31112 - cost about $5. Maybe you can get by without it, by using a screwdriver and hammer, but the tool was easy and risk free. You also have to stop the piston, as the previous poster said. I Googled how to do this, and the consensus seemed to be that it's easiest to stick rope down inside the cylinder, avoiding pusing it through the exhaust port. That worked like a charm. I used a hammer to hit a wrench on the clutch tool to break it loose.
Many thanks to the original answerer for getting me on the track to solving this.
Posted on Dec 17, 2008
  • 188 Answers
SOURCE: Worn plastic drive gear
Here is a link to the owner's manual... http://12.153.20.74/manuals/107705-01V.PDF. The part you need is 107713-01. You can order it online at www.masterparts.net or by calling 800-446-1446. They should have it in stock. I hope this helps.
Posted on May 21, 2009
VtToolMan
  • 704 Answers
SOURCE: I have a 6 month old remington 16
Try Master Distributors, they have them in stock for under $10 (plus shipping).
Here's a link to the part you're looking for.
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=107713-01
You can also give them a call and provide them with your model number of your chainsaw. Your sprocket number is #107713-01
Hope this helps you get cutting again! Best regards!
Posted on Jul 31, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington SL4 chainsaw gets fuel but does not fire
She has points and most likely a condenser.
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/7c5ef158cb0d092988256d35001fa737?OpenDocument
I'd try that site for any help or parts for this Grand Old Lady.
I did a search for "Remington SL4" and found quite a few threads here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Please be kind to her. HTH
Lou
Posted on Oct 25, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington electric chainsaw is leaking oil. How
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then clicked search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown"
It may help answer yuor question. RemingtonPower has production and replacement parts are very to find.
I've 7 chainsaws. 6 of them empty the oil tank overnight if I don't empty it. HTH
Lou
Posted on Nov 11, 2009
Testimonial: "found the manual and the parts diagram. Just what I needed. Thanks"
My 2004 chrysler sebring its a 2.4 liter engine when I turn it on the engine makes a weird nose like if sumthing in the engine isnt rotating right what could it be
look for loose or missing starter bolts,the starter drive pinion gear either worn or damaged or flywheel gear teeth worn or broken. noise you hear if it sound like starter grinding noise check starter mounting bolts could be loosen or 1 missing or drive pinion gear or flywheel gear teeth worn or broken.
Feb 11, 2012 | 2004 Chrysler Sebring
Have a problem with my electrical Kraftsman chain saw, the engine is running and the chain is rotating, but when I put it against the tree for cut, the chain will stop rotate bot the engine is still...
The main drive gear is slipping. This is caused by etiher worn teeth or worn bearings. If you pass the model number I can show you a diagram of where to look and what part or parts that have most likely failed. The drive gear is the weakest link but the motor can be shifting in the housing away from the drive gear. It only takes a bit less than 1/8 inch side play. The model number will be similar to this 358.341160
Most likely it is item 26 of this diagram:
http://c.searspartsdirect.com/lis_png/PLDM/P0101241-00001.png
This example is for model 358.381160
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358341160/0247/1503210/P0101241/00001?blt=06&prst=&shdMod=
Thanks for choosing FixYa, Kelly
Sep 13, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
Gbc shredmaster 5550x: this machine has badly worn plastic gears & one has teeth missing. Is a rebuilt drive unit available?
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now.
FixYa.com is not a parts or repair depot.
Thanks for your question today at FixYa.com
Jan 27, 2011 | Quartet gbc Shredmaster 5550X Confetti-Cut...
Internal gear slipping ,seems like rart of gear
you may be able to fix your problem by tightening up the chain a bit more. other wise, you may have to have that gear replaced because as you indicate it may have had it's teeth worn down. i would begin by tightening the chain.
Aug 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a TroyBilt electric chain saw and need geardrive
Your manual downloads from MTDProducts.com. This is the parts outlet for MTD. Troy-built is listed here:
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_BuyMTDOnline_10101_19502_-1
I clicked"
PARTS CATALOG "Troy-Bilt" enter
FIND YOUR PART "OPTION 1:" click the wrench
Model Name/Number: I entered "tb4516" and your parts list appears.
Your manual lists this phone number 1 (800) 520-5520. Please try them if the above isn't satisfactory.
GL
Lou
Jun 03, 2009 | Desa International 100089 06 Electric...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
1997 yamaha timberwolf 4 wheel drive only front wheel drive work
check to see if driveshaft to rear is turning.if it is, either the ring gear & pinion gear in the differential are not making good contact either from being worn, or out of alignment due to worn bearings in differential case,or both.check if axle has back & forth play in differential,indicating worn beaings. also could be worn ring gear to axle contact in differential.check for vibration in axle while in gear increasing as you give it more gas, caused from ring gear teeth slipping past teeth on axle.they would have to be replaced together. oversize wheels & tires tend to accelerate axle/ring gear contact teeth.
Feb 16, 2009 | 2003 Yamaha YZ 250
Oct 16, 2008 | Desa International 100089 06 Electric...
Broken plastic gear tooth - Fellowes P55-C Shredder
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Sep 13, 2008 | Office Equipment & Supplies
Desa International 100089 06 Electric Chain Saw Logo
59 people viewed this question
Top Desa International Garden Experts
Roland W VanLue
Roland W VanLue
ray gallant
Tim Whalen
Are you a Desa International Garden Expert? Answer questions, earn points and help others
