When i click on my firewall icon i get the following message: Windows firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service? What does this mean? I am trying to turn on my firewall.
This is an error when some crucial Firewall services are not running. Make sure that the following services are running and are set to start automatically:
Windows Firewall (MpsSvc)
CNG Key Isolation (KeyIso)
Base Filtering Engine (BFE)
Firewall Client Agent (FwcAgent)
Read the following Microsoft article KB2530126. The batch file mentioned in "Method 3" can be downloaded here. Just save the file, unzip it and run the batch file by double-clicking. It will start the services and set them to autostart.
Antivirus softwares have grades of performance functionalities. The most functional are norton antivorus that has out performance ratings on most operating systems. Norton comes with a complete windows utilities functionalities to protect the windows programs, quarantne any unwanted programs, perform systems tune ups like defragmenting, and selecting the approapiate programs only that improves the computer experince. consider acquiring norton antivirus.
also, webroot antivirus is a development software and depending on the condition of your computer could have become impediment to program functionality. Norton antivirus should quarantine and extract the webroot.
The ICS service can be enabled along with teh Port 9000.
Connection Sharing (ICS) service at the command prompt by using the net start sharedaccess command, you see the following output:
C:\>net start sharedaccess The Windows Firewall/Internet Connection Sharing (ICS) service is starting. The Windows Firewall/Internet Connection Sharing (ICS) service could not be started. A system error has occurred. System error 16405 has occurred.
Hope this will help you.... Cheers!!!
Vivek The system cannot find message text for message number 0x4015 in the message file for BASE.
The issue definitely is associated with Norton. I have Norton Internet
2009. To get rid of the error, the following needs to be done.
* Right Click on the Norton Protection Center Icon from the system tray
* Select Norton Internet Security
* Click Settings
* Under Basic Security, click Auto-Protect
* Click Configure
* Under Real-Time Protection, take the checkmark off "Turn on scanning for Micorsoft Office documents"
click start, then run, then type services.msc a box will appear, scroll down to the windows firewall service and right click on it, make sure it is started, then check your settings again,
Good Luck...
Symptoms: After you run Microsoft Windows AntiSpyware (Beta) or other anti-virus/spyware/adware software, 1) you may receive one or more of the following interactive error messages:
Could not start the Windows Firewall/Internet Connection Sharing (ICS) service on Local Computer. Error 10047: An address incompatible with the requested protocol was used.
or
Windows Firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service?
or
This application has failed to start because SPORDER.dll was not found.
2) Third-party networking products may not function correctly.
3) Computers may not be able to connect to the network because they cannot obtain an IP address.
4) You may receive the following error message when you are using Microsoft Internet Explorer:
Error 404: Page cannot be displayed.
Cause:
There are known spyware programs that install layered service providers (LSPs) on client computers to gather user data. When Windows AntiSpyware (Beta) removes spyware programs, it also removes the spyware-based LSPs. However, Windows AntiSpyware (Beta) does not restore any LSPs after it removes the spyware.
Resolutions:
How to rebuild the Winsock LSP chain on Windows XP SP2
How to rebuild the Winsock LSP chain on Windows XP, XP SP1, and Windows 2000
__________________ Bob Lin, MS-MVP, MCSE & CNE How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service. Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
Issue
After installing the all-in-one and restarting the computer, the following Generic Host Process for Win32 Services error message displays:
Windows has shut down a process for Win32 services: Data Execution Prevention - Microsoft Windows To help protect your computer, Windows has closed this program.
Solutions
The following solutions should be tried in the order they are presented. If the first solution does not correct the issue, proceed to the next solution; if that solution does not correct the issue, proceed to the last solution.
Solution one
Uninstall and then reinstall the software using the following procedure:
Uninstall the software by inserting the software CD that came with unit into the CD-ROM drive on the computer.
NOTE:
If the startup screen does not appear, double-click the My Computer icon, then double-click the CD-ROM icon where the all-in-one disc is inserted. Choose the Uninstall option. If the Uninstall option does not display, the software is not completely installed. Proceed to step 2.
Install the software by inserting the software CD that came with unit into the CD-ROM drive on the computer.
NOTE:
If the startup screen does not appear, double-click the My Computer icon, and then double-click the CD-ROM icon, where the all-in-one disc is inserted. Choose the Install option.
Run the Software Update from the HP Director and apply all patches.
Solution two
Uninstall the all-in-one software using the CD that came with the unit, by following the steps in Solution one above.
After the software is uninstalled, restart the computer.
Install the all-in-one software by following the steps in Solution 1 above. After installation is complete, verify that the unit works correctly.
Change the Windows Image Acquisition (WIA) service from Automatic to Manual by performing the following steps:
Right-click My Computer , then select Manage . The Computer Management window opens.
in the Computer Management window, click the plus ( + ) sign next to Services and Applications .
In the list below Services and Applications , select Services .
In the right-hand side of the window, right-click Windows Image Acquisition .
Select Properties .
Change Startup Type to Manual .
Click OK .
Close the Computer Management window.
Add hpqtra08.exe to the Windows Firewall Exception list by performing the following steps:
Click Start , then Control Panel . (Click Start , Settings , then Control Panel if you are in Classic Start menu mode).
