Question about Dryers
I have a whirlpool dryer. everything works, except it does not heat up. it is cool air.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Whirlpool dryer no longer heating
You have either a bad thermal cut-off, heating element or fuse.
May 06, 2012 | Whirlpool Dryers
I have a LEN3434AWO Whirlpool dryer. Everything is working fine except there is no heat. Please help! Thanks!
heatman101
Nov 23, 2010 | Whirlpool GEW9250 Electric Dryer
My GE Dryer.. serial number GL 733 568A. Do not dry clothes, everything else work, except getting hot enough to dry. The dryer just blow cool air..
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | GE Dryers
No heat, just cool air no matter what the setting it is on.
heatman101
May 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer got really hot one night and 3 nights later it stopped working. I checked all of the electrical and everything has power except for the timer.
Did you check the thermostats in the air tube going from the blower to the drum?
Sometimes a faulty thermostat will cause the over-heating problem you mentioned. This may also lead to heating coil failure.
A thermostat problem could lead to the dryer not running also.
Hope this helps
Sep 30, 2009 | Whirlpool LER4634J Electric Dryer
My dryer will not heat and timer works until the cooling stage
It's either the timer or insufficient air flow. check your vents to see if sufficient air is coming out.
Jul 07, 2009 | Dryers
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer is acting up
Sounds like you've done everything except check for air flow? When you run it, do you get ANY air flow thru the vent? If not , then your blower is either defective, not working or clogged.. Hope that helps..
Aug 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
