Question about Whirlpool LER4634J Electric Dryer
My LER4634JQ1 dryer stopped working yesterday. If I press the start button nothing happens. What can I check..I think it is something minor. This is the first time the dryer has ever stopped working. It was bought in 2003.
  • 903 Answers
There are many things that could be keeping the dryer from running. The first thing to check is the start switch itself. When you press in the switch, it should complete the circuit that powers the dryer motor. If you disconnect the dryer's power cord, take off the rear panel, and disconnect the switch, you can check it with a multimeter to make sure it changes state when you activate it. If it doesn't change state, the switch is your problem, and you can either take it apart and repair it or replace it.
If it does change state, the switch is good, and your problem lies somewhere else in the circuitry. It's probably not something minor at this point, and you should have a professional look at it.
Posted on Sep 14, 2010
Dryer sometimes works and sometimes doesn't, what's the problem?
i have a feeling that it's a fault in the power chord, take it out and double check. it would make sense if it only work now and then after you have plugged it back in because it could have made the wires touch again to make it work
Jun 29, 2014 | Whirlpool Washing Machines
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
I press the start button and nothing happens. I ran the dryer yesterday and it worked fine.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 23, 2011 | Roper Dryers
It wont turn on, brand new.
Hmm!! seems a little bit silly but did you ring the installer?.
If it was done yesterday they have a duty to support the installation be it major or minor
And it should be free
Apr 23, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
Dryer won't turn on
its a thermal fuse open up the back make sure you unplug it and turn off the gas its on your lower left side of your blower housing its skinny and white and about a inch in a half long and has 2 connectors going to it if any problems let me know
Mar 28, 2008 | Dryers
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
163 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
