Question about Char-Griller Grilling
Wont heat up past 150 degrees maybe bad thermometor?
  • 10865 Answers
SOURCE: wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
Posted on May 27, 2009
  • 57 Answers
SOURCE: Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Posted on Jun 27, 2009
MNfisherman
  • 11896 Answers
SOURCE: Our oven is not heating up past 150 degrees. The
The element will have to be replaced if there is no power going to it.
Posted on Jul 20, 2009
  • 197 Answers
SOURCE: Wont heat under 225 degrees
could be your thermostat
Posted on Oct 03, 2009
  • 30 Answers
SOURCE: Oven won't heat past 150 degrees.
you either have a bad bake element or control. also check wiring between
Posted on Mar 27, 2010
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Used self cleaning and now wont heat past 180 degrees
Sounds like you burned out the oven ignitor. A simple fix with a few tools and common sense.
Dec 13, 2013 | Whirlpool GGG388LXS Stainless Steel Double...
No heat in car
first thing to check would be the thermostat, if it is stuck open or opening too soon your temp will not get hot enough to throw heat.
Oct 14, 2012 | Cars & Trucks
On "bake" my GE profile
make sure the display is correct put a thermometor in oven to get correct reading
Mar 18, 2011 | GE Ovens
Mar 25, 2010 | Kitchen Ranges
Oct 02, 2009 | Kitchen Ranges
Jul 20, 2009 | GE Spectra JBP84 Electric Kitchen Range
Burner lights, fan wont come on, fan runs on manual setting, has new fan switch set at 110
YOUR FAN ON SETTING IS THE SECOND SETTING ON THE SWITCH .THE LOWEST SETTING IS THE TEMP AT WHICH THE FAN CUTS OFF AT THE END OF A SUCCESSFUL HEAT CYCLE. THE THIRD SETTING IS THE TEMP AT WHICH THE FAN COMES ON MAYBE 140 ISH. THE THIRD SETTING IS THE TEMP AT WHICH THE BURNER IS SHUT DOWN IN AN OVER TEMP SITUATION SAY 200 . THEN CONSIDER THE FACT THE SETTINGS ON THE DIAL ARE VAGUE. ACTUAL TEMPS MAY BE 20 DEGREES DIFFERENT, AND PROPERLY SETTING IS USUALLLY DONE WITH AN ELECTRIC THERMOMETOR.
Oct 25, 2008 | Coleman Heating & Cooling
Freezer temp
either stat is bad or charge is low. bypassing stat will achieve desires temp. if not then charge is low. if charge is low then buy new. if compressor valves are bad then buy new. to expensive to fix these days. new is cheaper. good luck. stat is power lead in , power lead out. kill power then tie em together to get constant on. be sure yor thermometor is good. i just spent 20000 dollars fixing ref at a hospital, only to find there thermometors were bad! good luck.
Jul 29, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Grilling Logo
20 people viewed this question
Top Char-Griller Grilling Experts
Dan Webster
Dan Webster
Michael Vincent Cruz
doylesouders
Level 1 Expert
Are you a Char-Griller Grilling Expert? Answer questions, earn points and help others
