Question about Samsung HP-R4252 42 in. Plasma HDTV
I can not remove the y-sustain pcb after removing all the screws and disconnecting the cables. It has three large heatsinks that seam to be holding the board down. Is there a way to get this pcb off the chassis?
  • 201 Answers
If you are sure all the screws are out then there usually isn't anything else holding it down. The connectors on the side where it plugs into the buffer pcbs along the side are usually very tight and require some persuading with a flat head screwdriver. There might be a piece of rubber underneath the board that is sticky on both sides/ They sometimes use that I think to help prevent it shorting to the chassis. I have had some that were on pretty tight making you think it was still bolted to something.
Posted on Sep 11, 2010
How to replace dc controller board on hp cp5225n
Remove 5 screws from rear cover and remove it
Open the right door to expose 2 screws holding right cover, release tab and remove Right Cover
disconnect 22 cable connections and 6 flat cables from the DC Controller PCB
Disconnect 3 intermediary wire connections and release the cables from the cable guides on the top and right sides
remove 4 screws from the 4 corners of the DC Controller
Remove PCB
Oct 01, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
How to change the coil in a 2004 ford freestar 3.9L
The ignition coil on a 2004 Ford Freestar is a bit of work to replace. Here are some steps:
1. Disconnect the negative battery cable;
2. Remove windshield wiper arms (you might need a cheap puller to get the arms off the spindles), marking the windshield with tape to help you reposition the wiper arms;
3. Remove the trim screws from the upper cowling and remove the cowling;
4. Remove a bunch of screws from the lower cowling, taking care not to remove the screws holding the wiper motor onto the lower cowling;
5. Remove the lower cowling with the wiper motor attached;
6. There is a large black piece on the passenger side of the car that covers up a big part of the engine. There are three screws that if you loosen you'll be able to remove this part;
7. Now you can get to the ignition coil, which is on the back of the engine; remove the wires (marking where the go);
8. There are only three screws that hold the coil on. Two on your right and one on the left (as you look into the engine compartment). Remove the three screws and the coil comes right out.
Sep 10, 2011 | 2004 Ford Freestar
I have fender passport pd-250 the protect light on and the power light geos off
One or more of the power transistors are shorted. There are eight transistors in the amplifier section - 2 high & 2 low for each channel. This unit is difficult to open up to work on.
Unplug unit and check speakers with a multimeter to make sure they are not shorted.
Take off front panel (8 screws).
Remove power supply shield with yellow tape (2 screws).
Remove 2 screws holding top of power supply, loosen bottom screws.
Replace front and hold in place with a couple screws.
Turn unit around.
Remove screws holding heatsink (6 screws)
Open rear storage door.
Carefully pull amp section out, being careful of tightly routed wires. Note any connectors you disconnect.
The amplifier is the board on the top, the power supply is in the silver box.
Push the power supply forward and loose the black screws holding the amplifier board bracket closest to the heatsink.
Loosen the top brass screws holding bracket to heatsink and remove the bottom screws.
Remove all eight of the screws holding the transistor brackets & transistors to the heatsink. Look and take careful note of how the plastic insulators weave through the transistors. If you get this wrong, you can short out the whole amplifier when you turn it on.
Slide the amplifier board down and out where you can get to the bottom. Note the wires and connectors going to the small protect board over the amplifier.
Check the transistors with a multimeter to find the shorted ones. Remove and replace bad transistors. These are connected in pairs.
Reassemble in reverse. Be careful of reconnecting wires and insulators. Don't test until the amplifier PCB is back in place and you're sure of all wires. If the PCB is touching the power supply, you'll short it out.
Good luck, I told you this wouldn't be easy!
Mar 04, 2011 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
How do I remove the y-sustain board from a philips 42pf7321d/37 plasma tv? i have removed the screws and cables? It appears there are three heatsinks that are mounted to the board and the chassis but none...
I think rubbers under the board hold the board(these rubbers prevent the board touch the panel). I had the same problem. After make sure you remove all screws, pull the board harder from one edge.
Sep 12, 2010 | Philips Televison & Video
I have the passport p-250 i left it on over night and when you turn it on the red comes on that said protect thanks jimmy
Turn unit around.
Sep 08, 2010 | Lectrosonics FENDER PD-250 PASSPORT SYSTEM...
Need to remove cpu fan
STEP 1Always start laptop dis assembly with removing the battery.
STEP 2
Remove six screws securing the hard drive cover and the heatsink covers.
STEP 3
Remove one screw securing the hard drive to the laptop base.
Disconnect the hard drive and remove it from the hard drive bay.
STEP 4
Remove three screws securing the CPU heatsink to the system board.
Carefully lift off the heatsink off the laptop CPU.
STEP 5
The heatsink is 100% clogged with lint.
If your heatsink is clogged, clean the heatsink with a canned air to prevent your laptop from overheating.
Mar 08, 2010 | Toshiba Satellite A45-S150 Notebook
Battery replace
Flip the unit over so it is resting on th screen with the on switch at the top you will see the reset and S/N tag. Pull this plastic tag off with twezzers or a knife. This will expose 2 torx screws size T-5. After removing the torx screws, right under the S/N plate sticker is a mount hole, locate this then pry apart with screw driver, be careful prying apart as there is a flex cable taped down to your pcb board. Remove the flex cable by opening the latch for it, there are 2 latches one small and one large and the cables are taped to the pcb board. Remove the speaker jack wire with tweezers.Next with a small jewlers screwdriver remove 3 phillips screws size ph00 from pcb board. Lift the pcb board out and disconnect the battery wire underneath. Next remove battery, it is stuck down with double sided tape and takes quite a bit of force to remove. It is a Garmin LI-ion 3.7v, 1.25 AH battery.
Aug 28, 2008 | Garmin nuvi 200W GPS Receiver
How to change the LCD
Leo -
Replacement LCDs are available for just about every make and model of laptop on Ebay, generally for a reasonable price.
However, installing a new LCD in a laptop can be a difficult operation; I highly recommend having the installation done in a repair shop.
If you do decide to try installing a new LCD yourself, here are the basics:
There are several screws you need to remove. On the bottom of the computer are generally between two and six screws that hold the power/hinge bezel in place, as well as the keyboard. Remove these screws and CAREFULLY pull up the bezel. The keyboard may also have screws under that bezel, remove those before lifting the keyboard (usually doesn't have to be completely disconnected, just shifted aside, but don't stress the ribbon cable that connects the keyboard to the motherboard too much).
With the bezel and keyboard out of the way, you should see a cable that connects the motherboard to the LCD through one of the LCD hinges. Disconnect that cable.
The plastics covering the LCD should have a handful of rubber or plastic 'plugs', between four and ten of 'em, with small screws located underneath each. Remove these screws, then very gently use a small flathead screwdriver to pry the LCD plastics apart at the seams along the side.
Once the front plastics are removed from the LCD, disconnect the long, slim PCB that rests beneath the actual screen. Remove the screws that hold the screen to the mounting brackets along its sides, and the LCD should be loose. Carefully lift it from the rear plastic cover, and you'll see a ribbon cable connected to the display. Release the clips that hold the ribbon cable in place on the screen, and you're ready to put in the new LCD!
I know its long and circuitous, but repeat the steps above in reverse to install the new screen.
Hope this helps!
-thinstatic
Jun 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Replacing the screen on the 7330gz
CHPMarine -
Replacing an LCD screen in a laptop is no simple process; It generally involves dismantling a LOT of the computer just to access the connectors and brackets for the screen. I recommend having it done by a tech if you can - take a look at www.craigslist.org to find a tech in your area in need of work; many people will advertise tech support under the Services Offered position for a very low cost.
Otherwise, there are several screws you need to remove. On the bottom of the computer are generally between two and six screws that hold the power/hinge bezel in place, as well as the keyboard. Remove these screws and CAREFULLY pull up the bezel. The keyboard may also have screws under that bezel, remove those before lifting the keyboard (usually doesn't have to be completely disconnected, just shifted aside, but don't stress the ribbon cable that connects the keyboard to the motherboard too much).
Hope this helps!
-thinstatic
Jun 12, 2008 | Gateway 7330GZ Notebook
Broken connection on power jack
for Aspire 5100
follow this step.
from backside
1. remove battery
2. remove hard drive cover and hard drive
3. remove the thermal cover, remove wireless card and antena cable.
frontside.
1. remove the power button cover.
2. remove keyboard.
3. remove lcd cable, wireless antena.
4. remove the lcd screw (2 long screw and 2 short screw)
5. remove the lcd screw from the back side (2 short screw).
now the lcd is separated from laptop body.
from backside again,
1. remove fan, there are 2 screw that hold the fan
2. remove heatsink (4 very short screw)
3. remove all screws from backside, there is 1 screw hidden "under" heatsink. it's short scew (longer than heatsink screw).
from frontside, remove 2 screw on top part of the laptop body.
and than you can remove the uppercase now.
after you remove the uppercase, remove 2 screw that hold modem, and remove 1 screw (very short) on bottom part, it's close to touchpad button. remove power switch board and modem and then remove the speaker cable and mic cable.
that's all you can take out the motherboard.
note: just remember to use the correct screw when you put it back.
i hope this will help.
Feb 26, 2008 | Acer Aspire 5100 Notebook
Samsung HP-R4252 42 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
