Question about Kenmore Refrigerators
My Kenmore Elite refrig./freezer (2 doors refrig on top, 1 pull out drawer freezer on bottom) is not working correctly. The front panel where the temps are set, light, etc. now has flashing lights that rotate to each control and will not allow setting. The temp in the refrigerator has risen considerably, not so much in the freezer, but even the freezer seems less cold. Is there anything I can do myself?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
Error message 1F on refrig
I have the same model and had the same problem after 3 years of use. I checked this and other sites and here's how I fixed it -- easy, peasy.
1. Turn off the power to the refrig. I have a ckt breaker for the refrig so I didn't have to pull it out of its alcove.
2. Open the bottom freezer section, pull up on the front of the middle drawer and pull it out. If you look to the back inside wall of the freezer you'll see 3 vents.
3. Make a platform that will support a common hair dryer to bring it up to the level of the central vent. I used a couple of packs of napkins topped with a towel.
4. Turn on the hair dryer. I left it on for about an hour and heard two chunks of ice fall free at about the 15 and 30 minute points.
5. Remove the hair dryer and platform, put the middle drawer back in the opposite of how you removed it, and close the freezer section.
6. Turn the power back on.
7. Put a towel on the floor to catch the water from the melting ice chunks.
It's been 24 hours and the error has not reappeared.
If this doesn't work, then other comments suggest that it may be the related circuit panel and you'll need to call in for repairs.
I hope that this helps.
Feb 11, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have an LG refrig french door model LFX 31925ST/00. Purchased less than 2 months ago. The top plastic freezer door continues to get an ice build up on the front of the drawer only. Is this normal? ...
It sounds like a loose or bad seal on the top area of the freezer door. Use the old dollar bill test to see how good the seal is. Hold a dollar bill up to the seal and close the door. there should be some resistance. compare the resistance between the top and bottom of the door.
Nov 06, 2017 | LG Refrigerators
I just bought a house with a Kenmore stainless steel bottom drawer freezer. The freezer drawer does not close completely and large amounts of snow and ice accumulate inside. I have taken the drawer out,...
Check top see if the arms of the drawer are fully seated into the rails which support it and extend from inside the freezer when the drawer is opened. On most french door refrig's, there are hooks on the back side and tabs on the front side which are sometimes hard to get back in. Then the door is locked into the rail with a screw at the point where the rail meets the freezer door.
Aug 21, 2010 | Kenmore 73503 Stainless Steel Bottom...
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Kenmore Elite Trio 795.7756 /7757 problem
I had the same problem, freezer full of groceries defrosting or crisper drawer freezing produce. Sears Appliance Repair sent servicemen out twice and both times I was assured the problem was fixed. After freezing produce the third time I insisted they come and get the faulty appliance. The replacement has worked perfectly since day 1. INSIST ON A REPLACEMENT
Sep 03, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
