FixYa.com
Tags:
IBM Fan Heatsink CPU Heatsink & Fan, Fan Assembly
CPU heatsink/fan help!
By Hart - usenet poster
Well, if it's not one thing it's another...
While putting new RAM in my machine, when I opened the case of my
machine, the CPU heatsink/fan fell out.  It looks like this is the
type that glues onto the CPU.  Unfortunately, I have absolutely no
idea what kind of glue to use and if there are any hidden gotchas.  I
have a tube of this stuff labeled "PC power & cooling heat sink
compound", but I suspect this is for clip-on heatsinks.   All of the
PC repairs books I can find just say it glues on and no other
information.  Can anyone give me some more information??
Damon
d @inetnebr.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Odud
Odud - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I agree, but have one question.  The 1 oz. tube would last a lifetime
with respect to volume alone,  but I would think that the product will
break down chemically after a few years.  Could someone with knowledge
in this area post in response?  Thanks.
Matt
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
Silicone should not break down at all, since it is "neutral". That's why
they are using it for breasts implants.
Matt <mspa @bellsouth.net>
: I agree, but have one question.  The 1 oz. tube would last a lifetime
: with respect to volume alone,  but I would think that the product will
: break down chemically after a few years.  Could someone with knowledge
: in this area post in response?  Thanks.
Solution #3
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
On 4 May 1997 15:20:00 GMT, "John" <x @digicron.com> wrote:
If that`s the case, then why all the law suits concerning breast
implants?
Solution #4
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
If I'm not mistaken, the Radio Shack thermal goo is silicon grease with
zinc oxide particles mixed in.  The same sort of goo is used between a
semiconductor and its heat sink in all sorts of electronic equipment.
In my experience, after a few years, the grease thickens (breaks down
chemically?), leaving the zinc oxide.  I believe that the grease is not
that important to the heat transfer, but the many tiny grains of zinc
oxide fill small gaps and provide a large number of small thermal paths
of low resistance.  When combined, the large number of small paths
create a large one.  In emergencies, I have replaced the semiconductor
without replacing the goo, relying only on the leftover dried stuff on
the heat sink, and it worked quite well.
There are thermally conductive glues and pads (adhesive and
non-adhesive) that serve the same purpose.  If you have a CPU chip with
a factory installed heat sink, you can bet that the thermal
conductivitity of the adhesive was an important consideration.  I have
my doubts about the thermal properties of the adhesive used on some
after-market heat sinks.  However, my biggest concern about the
after-market heat sinks is that the adhesive always fails after a few
years, leaving a CPU with no heat sink and a loose piece of metal to
move around and cause electrical shorts.
Jerry Oakley, Chief Engineer            Voice/Fax:  (972) 613-0413
B & A Computer                              >>>>>> NEW E-MAIL ADDRESS:
2812 El Paso                            >>>>>> b @altinet.net
Mesquite  TX  USA  75150-4846
Solution #5
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
  I see no smileys here, so I'll assume you're serious.  It is not that
  the silicone "breaks" down.  But it must be the thinnest possible coat
  that still allows no voids.  If the system is in a tower case
(upright)
  it is possible for a thin coat to separate over time without a clamp-
  down fansink.  The clamp-down heatsink also halps squish the compound
  evenly, also minimizing voids.
  Keith R. Williams
  k @ibm.net
Solution #6
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
  It is *not* an adhesive.  It is normally a silicon grease and can be
  found in any Radio Shack.  It's benefit is not that it's a great
thermal
  conductor, but it is far better than air,  It seals the voids between
  the chip and the heatsink/fansink.  For this reason, this stuff must
  be used sparingly.  A very thin coat is best (a 1 oz. tube will last
  a lifetime).
  Please!  Clamp-down only.  The clip-on's and stick-on's don't hold
  tightly enough to eliminate/prevent voids in the thermal compound.
  Keith R. Williams
  k @ibm.net
Solution #7
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
The glue they use is either a thermal adhesive or thermal adhesive pad.
Using anything else will result in poor heat transfer between the CPU
and heatsink.
The only place you'll find thermal adhesive is through an electronics
distributor like Allied, Digikey, or Mouser. Some of the better full
service electronics supply houses should have it.
Either that or replace the heatsink/fan with a clip-on/strap-down type.
Tom Mosher
sds mark II
tmos @isource.net
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
