Question about Barska Optics Barska 1x30 Red Dot Scope Sight Ac10328
Setting up accuracy of red dot scope. Instruction manual needed
How open golden antler scope?
Instruction Manuals ' Tasco® - Believe it.
www.tasco.com/pages/instruction-manuals/
Golf Scopes; Infocus - 514FMY ... QP22 Electronic Open Reflex Sight · ProPoint Red Dot Scopes · Tasco Generic Riflescopes (6 Languages) · Vital Zone Reticle ...
bout 236,000 results (0.65 seconds) Search ResultsTasco Golden Antler 3 - (9 x 40 mm) Repair Questions ...www.fixya.com/.../p4821-tasco_golden_antler_3_9_x_40_mm_3_9x40Recent Tasco Golden Antler 3 - (9 x 40 mm) (3-9x40 mm) questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Spotting Scopes.Tasco Scope Problem [Archive] - Cast Boolitscastboolits.gunloads.com > ... > Cast BoolitsAug 1, 2009 - 12 posts - ‎10 authorsErgo, if you have a Tasco or Redfield optic that needs repair, use your ... Have a couple of "golden antler" Tasco scopes a rep gave me back in ...Tasco Golden Antler Riflescope - YouTube
Jan 24, 2016 | Tasco Golden Antler 3 - (9 x 40 mm)...
I'm sure this will sound stupid, I just bought a rifle with a Tasco red dot scope on it and have no idea how to activate the scope. Any help would greatly be appreciated. Thanks
No, that doesn't sound stupid. It's always a good idea to get all the information before using firearms and their accessories, and I'm happy to help:
The large knob on top of the scope is the rheostat, which is used to turn on the red dot, and adjust the brightness. It can be adjusted from "1" (dimmest) to "11" (brightest). You'll have to be looking straight down the scope to see the red dot, since it is only visible when you're aiming. If you turn on the scope to the brightest setting, and you look through like you are aiming, and the red dot is still not there (or very dim) then you probably need to replace the battery. It uses a 3 Volt coin-style lithium battery, type 2032. Unscrew the battery compartment on top of the rheostat and put the new battery "+" side up. Then replace the battery cover, and you should be good to go. Turn off the scope when you're done to save the batteries.
Since you bought the rifle with the scope already installed, it's probably already sighted in, or pretty close to being sighted in. Adjusting the windage and elevation on the red dot scope works just like other rifle scopes. The knob on top moves the point of impact up/down, and the knob on the side moves left/right. For this model, each click of adjustment moves the point fo impact by 1/2" at 100 yds, 1/4" at 50 yds, or 1/8" at 25 yds.
Be safe, and have fun!
Jan 24, 2011 | Tasco 1x30 Red Dot Sight BKRD3022
NEED INFO ABOUT ADJUSTING WINDAGE & ELEVATION ON MY MILLETT SP2 RED DOT. I LOST OWNERS MANUAL &NEED TO KNOW WHAT EACH CLICK IS EQUAL TO AT 100 YDS
the best way to sight in your red dot is clamp your gun in a gun vice or work mate? so it cant jump about!!!!!!! look through the barrel at a post say 100yds away then tweek the red dot or croos onto this post,,then test fire the gun and tweek the scope till its shooting were it points,,easy,,,
dont let the gun move at all,,,,you need to remove all the wobbely bits,,your the bigest wobbely bit?
an im not being nasty,,,you cant tweek a scope hand held?
Nov 27, 2010 | Millett SP2 Compact Red Dot Sight 5 Min...
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
Apr 17, 2010 | Cabela's Optics
I need a instruction manual on how to adjust the setting for accuracy
Can you clarify what name and, model of your scope other wise there is different manufacturing procedures and different settings. Dude, if your looking for a general idea google search it, because each scope is different. some marksman you are, none the less an imcompentance tactician
Dec 01, 2009 | Simmons Optics
No instruction manual for setting up and sighting the scope, where can I download one for theReddot sp2 sf-0907-0203. Also at higher power, the light source for the red dot is visible on the inner upper...
this is the way they are at high power,,, to set the scope up the easy way is clamp the rifle in a jig fire a round and were ever the round lands turn the turrets to put the red dot over the hit mark then fire another round at the target the bullet should be spot on the dot
Nov 12, 2009 | Millett Hunting Redot Sp Series 1in....
Need manual to set redt dot scope. don't know how
can you be more specific, what is the name and, model number of your optic kit, is it leapers?
Oct 19, 2009 | Tasco Red Dot 1 x 30mm Rifle Scope 5 MOA...
Barska Optics Barska 1x30 Red Dot Scope Sight Ac10328 Logo
130 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Vladimir Frolov
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
