Question about Hayward Navigator Pool Cleaner
Navigator seems to do only one side of the pool. Gets stuck by the stairs,,,can't seem to back up. I have replace the rubber feet. It moves ok for a while and then will just sit in one spot for hours\ Thanks for any help
  • 640 Answers
With these pool cleaners, there are several things that you should try. First, make sure that you have proper waterflow. Too little or too much water flow into the cleaner can alter the movement and cause the cleaner to stay in one area or hang on steps. Check and clean your rear screen and make sure that you cone gear rotates both ways smoothly.If none of these seems to correct the problem, you will probably have to replace the gear box.
Posted on Oct 11, 2010
My navigator gets stuck when it encounters the steps. It will not move but flaps around and does not move. I have changed the bearings, the flaps, the feet and have replaced anything else that has worn...
It could be that you have improper water flow. Use the water flow gauge and adjust the flow if necessary. It could also be a steering failure. Check the pool cleaners rear screen and clean it if necessary. Make sure that the cone gear is free and rotates smoothly in both directions. You could also need to replace the gear box.
Jul 06, 2011 | Hayward Navigator Pool Cleaner
Navigator gets hung up at curve going up the pool walls. It has plenty of suction, new rubber feet, clean pool filter running at 3000 rpm,turbine is moving freely with no debis, all suction going to...
You have check all of the things that I would usually recommend when these pool cleaners are moving properly. My additional suggestions would be to make sure that your hose is not too short (adding lengths of hose if necessary) and to check for steering failure. Check and clean your rear screen, make sure that your cone gear is operating smoothly in all directions, and clean, repair, and replace (if necessary) your gear box.
Feb 06, 2011 | Hayward Navigator Pool Cleaner
My Navigator Pro is 3 months old. The pads and wings are in good shape. I have plenty of suction, but the Navigator won't move. I didn't see anything stuck, but the rocking feet will not move. I thought...
You should be able to move them with your hands. If you can't, the only thing I can think of is that something is stuck in one or both of them. Remove the pods(the pieces on the sides) and clean them up including where they go into the body. The cleaner is too new to need any repair. Be sure when you put them back on that you tighten the screws all the way.
www.cpo2go.com
Nov 21, 2010 | Hayward Navigator Pool Cleaner
The Hayward Navigator pool sweep does not move. The pressure is 7.5, the suction seems to be okay, and the "flippers" move, but the pool sweep just sits there.
You may need to replace the pads on the flippers. You can get new 'feet' for your cleaner at any dealer . They just pull off and press on, They go on only one way so check the tabs before you press them on.
Please Vote !
Jun 06, 2010 | Hayward Navigator Pool Cleaner
The shoes are wobbling but the navigator won't move. took it apart and there are no obstructions
If you hold the unit tight and can stop the feet then your problem is most likley in the "A" frames and their bearings. The cams on the impeller will move them till they get a lode on them and they will seem to be moving but won't move enough to run the unit. Hope this helps.
Jan 25, 2010 | Hayward Navigator Pool Cleaner
Gets stuck on walls
turn down the suction if thats not the problem under the left rear pod on the body housing youl see a little straight slot for a screw driver theres 3 settings it actually shows images like a ladder turn the screw down to the first step that should solve your problem
Jul 17, 2009 | Hayward Navigator Pool Cleaner
Our Navigator goes around in circles and when it gets to the wall it simply stops. Everything on the outside seems to be okay and not very worn. Is this a gear problem or could something be stuck inside?
Internally, there is a part called the A-frame that has two wheels with ball bearings. There is one on each side and it is what causes the feet to move. Sometimes these wear out and the bearings fall out. This can cause one side to have more movement that the other thus walking in circles. See exploded parts view http://www.h2opoolproducts.com/product_info.php?products_id=48
Jun 26, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator gets stuck at wall
I have had the same Navigator for many, many years. I have replaced it's guts, pods, feet and gears whenever things wear out. I have a vinyl pool and it works great. I had a problem with it charging into the wall and just sit there beating it's feet ..... now this was my solution, and I'm surprised that Navigator has not altered the design to deal with getting stuck against a wall. This will sound CRAZY but it works great!! Take a plastic lid for a 5 gallon bucket and cut out a round-nose for the front of your navigator. The curved shape is prefect and you can notch the plastic lid and it will snug right into the Navigator body. This gives your Navigator a round-nose and it will never get stuck against a wall again.
Jun 01, 2009 | Hayward Navigator Pool Cleaner
Hayward pool vacuum cleaner problem
With this vacuum, start from the simplest possible problem and then work your way through. Process of elimination. Flip it over and see if the feet are all the in good shape. Also look to be sure that the springs that are below each of the feet are actually connected. Where they connect, the tabs break off and then the spring doesn't snap and that side of the vacuum will drag or go in a circle or not move at all. If that look s okay, you need to check the bearings to be sure they're okay. If one side goes you'll experience the same problems you've described. If they are tight, no bearings falling out then check the pods. That's the long sections where the feet and wings attach to the vacuum. As a general rule if you replace the pods, you should replace the Aframe as well. Not difficult and the parts will run $110-$125 for an entire bottom kit which includes everything that has been described above.
Oct 05, 2008 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
259 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
