Question about Cyberhome CH-DVD 300 DVD Player
I have changed the settings of our DVD player, and lost video picture. I cannot reset the player to its original settings. How can I do this? Please advise. Bill
    Genius:
  • Cyberhome Master
  • 1,550 Answers
Check on the dvd remote control for the progresive scan function and disable it
Posted on Sep 11, 2010
Memorex mvd2022 video setup
Download the user manual by this link, and refer it.
May 29, 2012 | Memorex MVD2022 DVD Player
Sony BDP-S350 - no video..only audio on all outputs
This is button config for master reset without picture:
Home Left button x 3 Down button x 7 ok (centre button) ok Down button x 6 ok Left button x 1 ok ok wait a couple of seconds for settings to complete, when you switch back on you should have a picture and be back at language set up screen.
Hope this helps.
May 30, 2009 | Sony BDP-S350 Blu-Ray Player
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Lost picture when set dvd player to progressive scan.
Hello Fearlessloki, Welcome to Fixya.
Would you mind posting some of the details on this DVD player that is having issues?
Jan 05, 2009 | Cyberhome CH-DVD 300 DVD Player
No picture
change the tv selection to av and check till the dvd reappears
Nov 15, 2017 | Samsung DVD-V4600 DVD Player/VCR
No picture after resetting by pressing stop button for 20 sec
Problem fixed: I realized that the problem was that with resetting the player it defaulted to the standard video ouput ie no longer sending signal through the component video. I used a standard video cable and connected player to tv with that and it had a picture. Then I changed the setting to progressive output and got picture signal through the component cable again.
Aug 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Changed Video Output Setting
Reset you player by doing the following:
With the player on, hooked properly to your television1.gif, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Screen is Looping Vertically
Try to connect to s-video tv and fixit ,another is conect to pc with tv card with s-video ,select pal in the program(ejem winvcr) and you can see the picture balck and white ,is ok to fix it.
Nov 03, 2007 | Protron PD-800 DVD Player
Changing to PAL format...
i have the same issue i don't know the solution to ur original problem of B&W.. I think you might have unknowingly changed the "Video Output".. don't worry...to change it back.. do the following steps 1) Switch on dvd player with no disc 2) wait for few secs and press setup on remote 3)press -> (rt arrow) once 4) press enter 5) press down arrow twice 6) press enter 7) press up arrow once(or twice) 8) press enter hopefully this shud work..
May 05, 2007 | Cyberhome CH-DVD 300 DVD Player
How do I reset this ilo dvdr05
To reset to user defaults for mu1 with no video: 1. turn on dvd with no disc 2. press "setup" 3. press "down arrow" 3 times 4. press "enter" 5. press "down arrow" 9 times 6. press "enter" More than likely you changed from interlaced scan to progressive scan. If your tv does not sopport progressive scan there will be no video. The default setting is interlaced scan.
Dec 07, 2006 | iLO DVDR05 DVD Recorder
Cyberhome CH-DVD 300 DVD Player Logo
170 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
