Question about Craftsman Garden
What is the spark plug gap setting for a Sears 32CC Gas Line Trimmer
    President:
  • Craftsman Master
  • 1,545 Answers
The manual from www.searspartsdirect.com says it is to be set at .025" according to the user manual:
http://www.managemylife.com/mmh/owner_manuals/24262/CRAFTSMAN-Line-Trimmers-Weedwackers-Gas-L0609794?brand_name_search=358791070+CRAFTSMAN
Please vote on this solution.
Posted on Sep 11, 2010
I have a craftsman 32cc weedwhacker trimmer and its brand new and it hasnt started from day one it isnt getting any spark at all
If you have spark problems, remove the wire and then remove the plug, reattach the wire and ground the plug to the engine and pull the string, you should see arc and hear it pop, if not, take the plug to another piece of equipment and remove that equipment's plug wire and attach it to the plug from the weed ******* and then ground it and test it. If still no spark, then plug bad, if plug then the weed ******* has a problem with the spark plug wire or the ignition coil.
If you have spark at first test, then the problem with the weed ******* is somewhere else.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
25cc Craftsman line trimmer: - will not start. - no spark across the gap of the plug - plug shows no corrosion.
Hello there and thank you for choosing fixya
normally on these when you dont recieve a spark and you are 100% sure that the spark plug is good than the only thing left to check is the ignition coil
It is what the plug wire is connected to kind of a square or round part these are nortorious for going out in small engines this is a 35 dollar part ok?
thee if this does not do it check the on off switch for continuity
Then finaly Check the flywheel cover, the magneto gap and starter coil if there's still no spark.
Read more: How to Troubleshoot a Small Gas Engine Trimmer ' eHow.com http://www.ehow.com/how_6306856_troubleshoot-small-gas-engine-trimmer.html#ixzz1LrUTc28o
May 07, 2011 | Craftsman 25cc Gas Line Trimmer
25" /1.5 cu.in. 2-cycle 17" cutting
Easy way to test plug is to remove it from cylinder head, then ground its hex base to side of engine..reattatch plug wire and pull starter cord...Do this is dim light...need to see a nice blue spark. So, do that...check the plug gap and plug condition (even if new)...if it's NOT firing...try another plug...if same...you will need to pull the engine covers off and check the "air gap" of the flywheel magnets to the pickup legs on the ignition coil module. You can gap it the thickness of a regular business card (.010"-.014"). The gap has to be present for the spark plug to produce a spark.
Jul 16, 2010 | Craftsman 25cc Gas Line Trimmer
Sears weedwacker won't start 358.797150
Plug could be fouled. Make sure you have fresh fuel mix.
Aug 19, 2009 | Craftsman 25cc Gas Line Trimmer
How can I determine if my husqvarna magneto is working?
Remove spark plug from the engine, reconnect it to the plug cap cable which come from the bobin.
Find a piece of steel wire jumper, atleast a foot. Make a jump from the metal body of the plug to the chassis of the engine.
Safety issue: Place the plug away from the spark plug's hole on top of the engine to avoid gas ignite.
Set the trimmer on the floor, set the gap of the spark where visibility while you pull the string.
Pull the start string and the arc could be seen right on the plug gap. Consider an Arc Purple or Blue coloration are good.
If the arc has not been seen, the Magneto need to be serviced.
Jun 11, 2009 | Husqvarna 28cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Garden Logo
976 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
