Question about Exercise & Fitness
When running the weslo cadence 70e, it makes allot of noise like it is too tight. How do I adjust the belt or is it something else that could be doing it.
  • 79 Answers
Whit a key allens turn around to the two bolt on rear rollers, turning it counter clockwise
Posted on Sep 12, 2010
Weslo cadence 70e doesn't come on , how do you trouble shoot the problem
If you wish to get some details about treadmill repair and service; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 02, 2017 | Weslo Exercise & Fitness
My cadence 825 had been unused for a while but now when I insert the plastic key the treadmill starts immediatly without my having control over it. where can I get some maintenance for this machine. Kevin...
RUN the software calibration for diagnose, troubleshooting , fix it.
adjust the speed sensor, clean it and tight the wires connector
LUBE the deck belt+rollers bearing too
SEE THE diagram.
God bless you
Jul 19, 2012 | Cadence Weslo 825 Treadmill Walking Belt
My Weslo Cadence 70e treadmill works fine, but the dislay doesn't come on at all.
1) Tight the ribbon cable very well, and tight the connector from display board vs. lower board.
2) Adjust the REED switch, see the diagram attached.
God bless you
Jun 08, 2012 | Exercise & Fitness
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
My Weslo Cadence 840 treadmill mat keeps trying to run off to the left
Check that the plastic end cap has not broken first. If it is OK, adjustment should be simple.
Start the machine running. With the allen key provided (3/16) simply tighten (clockwise) the left hand rear roller adjustment screw about 1/4 turn and observe the belt. If it is way off, you might need to turn 1/2. Let the belt do a couple revolutions before adjusting more. A very small adjustment id usually needed to straighten the belt. If it is way off, there may be a more serious problem..
Feb 26, 2011 | Weslo Exercise & Fitness
The walking deck on my Weslo Cadence 975sel slides to the right and causes a loud rubbing noise. How can I correct this problem? Thanks,
Find the allen key that came with the machine. If you don't have it, you will need a 3/16" allen key to adjust the roller.
If the belt is pulling to the right, adjust the right screw by turning it clockwise 1/4 turn with the belt moving. You may need to do this more than once. Between adjustments, watch the belt closely to see how much it moves to the left.
Unless something dramatic has happened to the frame or some other part, the amount of adjustment should not be too great..
Dec 17, 2010 | Treadmill Doctor Weslo Cadence 930...
Walking belt slows down to almost a stop when i get on it
I believe under the motor shroud on the circuit board their should be 2 pots 1 adjusts torque 2. adjusts speed try adjusting them and see if that take care of the problem if not. worse case it might be the drive motor.
Feb 27, 2010 | Cadence Weslo 4200 Treadmill Walking Belt
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
136 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
