Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
I can't get my delphi myfi sm radio to work even when I use the AC adapter on the cradle. For a while, it would work and then go off by itself. Now, it won't even go on. What's the problem?
  • 6,487 Answers
You should: Insert your MyFi into its home stand and plug the AC adapter into the wall to charge the battery.But if its really not charging a battery replacement is already needed for this unit and you can get the battery from a authorize service center.
Posted on Sep 11, 2010
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
The dial on Delphi MyFi is no longer functioning. Can it be reapired and where? Thanks, Chris
Very common -happened to me; cheaper to use a remote control than to get it fixed, or even buy a next generation radio.
Jan 23, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My delphi myfi xm2go will not recharge. What do I
New battery - make sure it's WHITE and not a black one as the black ones were recalled.
Nov 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Mine just started this recently.
Sounds like the battery is not charging. My solution was to use a small screwdriver to move the charger pin in the power adapter hole in the under off center. That gave it better contact, it began to charge properly and fixed my issue.
Aug 21, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
Replace the battery. Your Myfi will not work without it -- even if it is plugged into the charger.
Mar 03, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Radio works in the car cradle but not in the house cradle.
I posted on this myself looking for solutions, and then discovered the solution myself. The base pin connectors at the bottom of the receiver apparently become loose, and in order to make a good connection you need to push/pull the top of the receiver forward to achieve a connection. I first developed this problem in the home cradle, and used the car cradle in the house, then had the same problem with the car cradel. I fix it by jamming something between the receiver and car cradel at the top to force and hold it forward). In the home base, I pull it forward at the top, and prop it that way with something heavy behind it. No one ever posted on how to take the unit apart and actually fix the loose connection.
Jan 13, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
MYFI does not powerup
You may not be getting power through the base because of a bad physical connection between the base pins and the receiver, and it won't power up because it has no battery charge. Try plugging the AC power adapter directly into the bottom of the receiver (not through the cradle). Push the adapter plug toward the back of the receiver to see if the + sign on the battery on the top right of the screen shows that it is now receiving power and charging. Alternatively, with the receiver in the base, try pulling the top of the reciever toward you to tilt the receiver forward on the pins to see if it starts charging.
Sep 04, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
I have the same problem. I finally was able to get Delphi Tech Service and found out that these units have a flaw. they have been going out after about 14-18 months and there is no known repair... neither does Delphi offer a repair service for this problem.
Dec 17, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
96 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
