How do i open the logitech mouse to change batteries
  • 166 Answers
SOURCE: Laser Mouse MX 1000 By logitech
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Posted on Dec 29, 2007
SUPERMAN_B_1
  • 294 Answers
SOURCE: Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
Posted on Mar 28, 2009
SOURCE: Logitech USB mouse Model # M-RAG97-does it have an
Turn mouse over - 2 screws under label - you can see the idents
Two other screws under rerar - remove feet or just punch though
the feet to get to screws.
Best of luck
Colin
Posted on Apr 11, 2009
  • 125 Answers
SOURCE: logitech mouse and battery changing
If you look at the rear of the mouse, there is a little half circle button. Push that part in a little and you can remove the battery door thats just above that button.
Here is the webpage link to the manual in case you dont know where the button is.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=CuABMGxj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=3122&p_created=1145490467&p_olh=0
Posted on May 13, 2009
  • 77 Answers
SOURCE: how to change batteries of MK 250 mouse
I think you must need to take of the top part by slyding down
Posted on May 22, 2010
Testimonial: "Thanks"
How do I change the battery in a logitech wireless battery. I can't seem to figure out how to open it to even see what kind of battery is needed.
For changing the batteries of logitech wireless.I guess a video tutorial will help you out rather than written instructions. Watch it to lean how to replace battery of the logitech cordless mouse ( Logitech MX 1000 Model). If you are having a different model please specify the details of your model.
Mar 02, 2011 | Logitech Cordless Mouse
How do I change the battery for my logitech cordless mouse? Can't find opening for battery....
hi marlys, i am happy to assist , Ya its not too easy to replace battery in logitech cordless mouse,in the back of mouse, you have mouse pad just remove it , you can see they provision to remove the mouse, there been Four screws been inside that mouse pad, But before going to open your mouse just check you have new battery with you, if you connt find in any shops just go to eBay , you can get it thee, If you mansion the excate model name of your mouse mean i will send video for that particular model itself , no issue just check out this video
Jan 06, 2011 | Logitech Cordless Mouse
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Re battery change
First ,You will need you model number, then go to the Logitech website and download a manual for your mouse:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_alp.php?p_sid=fycUb4Ph&p_lva=&p_li=&p_page=1&p_cv=&p_pv=2.
Dec 30, 2008 | Logitech Cordless Mouse
How do it change the battery on cordless mouse?
On a lot of Logitech mice there is a button under where the little receiver stores.It has a picture of a battery on it. Push the button and the back will lift off.
Dec 06, 2008 | Logitech Cordless Mouse
Hi I have cordless Logitech mouse that was working until yesterday. Not sure if I have to change battery. If this is the case, how/ WHERE do I open the mouse to change the battery?
The battery holder is on the top of the mouse directly under the palm of your hand. simply push the surface away from the mouse buttons and it should pop open.
Nov 27, 2008 | Logitech Cordless Mouse
Logitech wireless mouse
Went onto laptop today and mouse is working - don't know why !
Sep 10, 2008 | Logitech Cordless Mouse
Where's the batteries?
I had a similar problem with my battery going dead in my Logitech mouse. There was a "aa" battery located under the rear top cover. it's the part that has the Logitech logo on it. You simply press the button underneath the mouse @ the back that has a LOCK symbol on it & lift off the cover. Put in a new battery & you should be good to go.
Fred
Oct 01, 2007 | Logitech Cordless Mouse
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
