Question about Selkirk #105082 5"-12" Adjustable Pipe
I am installing a selkirk chimney on a tin roof, how do I guarantee no leaking around the base? It is an ongoing problem, has built up with ice in the winter and leaks through the roof, do I use flashing? If so what is the best way to install it?
2 Suggested Answers
  • 112 Answers
SOURCE: I have a 3 ft stainless double wall chimney that
You can use metal strapping with short self-tapping sheet metal screws also where it penetrates roof a metal collar on inside should be used and a roof collar approved for B-wall vent pipe to keep water from leaking inside on outside on the roof.You can penetrate outside of B-wall vent pipe with short screws to secure the pipe just don't penetrate both pipes.this outside pipe is just a insulator to keep heat from transferring through pipe.
Posted on Jun 14, 2011
I have a free standing wood burning stove Hearth Stone brand Is there a product that one could wrap the chimney flue with to avoid a small child from burning its hand? Thanks
There is a completely double insulated flue pipe available on the market by SELKIRK and more
INSULATED stove pipe DIY CHIMNEY FLUE - YouTube
? 4:06
https://www.youtube.com/watch?v=D6AHJ_XbOCo
Oct 19, 2011 - Uploaded by ROCKNTV1
CHIMNEY FLUE DOUBLE WALL INSULATEDhttp://www.rockntv1.com/2011/10/insulated-stove-pipe-diy .. And see google for vendors
Nov 29, 2015 | Home
Is it necessary to put flashing around the chimney?
absolutely, if you don't do it you will have to tear up the shingles later and put it in when the roof starts leaking around the chimney
Jan 15, 2013 | Roofing
I have a 3 ft stainless double wall chimney that is going thru a ceiling/roof in my garage. there were no instructions on installation. how is this secured? Pls thx Jer
May 01, 2011 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
Want to know what the knob at the bottom left corner does? It looks like it opens a air vent. This is for a Majestic fireplace. Model no. 18103269 about 21years old. New home owner.
It may be similar to the Dutch West wood burning stove. The air from two front inlet flap opennings at the left and right of the glass door direct air upward and then inward at the top of the flame. This is intended to swirl the flame back so that it actually revolves in there before coming back and up the hole up into the top mounted reaction chamber where the platinum particles in the fiberous ring cause a catalyst type reaction of unburned gas. The main damper has to be closed to do this. You have to watch the flame to make it happen with the adjustment and the fire has to be up to about 350 degrees F. Because you are now making the flame roll around in there you will find the whole unit starts to snap with more heat output and if you use a magnetic KEL stovepipe thermometer it will shoot up to 420 degrees in 15 seconds so be ready to reduce the air to control your fire. Anything above 450 F. is dangerous, uses too much fuel and might send flames up to the creosote in the chimney. A clean chimney is fairly safe but the stainless steel ones with mineral asbestos lining by SELKIRK CANADA are the best as they will allow a fair number of seconds of CREOSOTE BURN which is kind of dangerous and can spit flame balls on to your roof, burning up cedar shake roof material before you can get up there with a garden hose and extinguisher.
Mar 28, 2011 | Garden
When it rains hard and there is a lot of wind the rain gets into the chimney and drips through a ceiling light. Is there a chimney cap that I can buy that will eliminate the problem?
Hello,Yes there is a cap for every size chimney BUT that (while always being a great idea) will only prevent a WASHDOWN & keep pests and leaves out.The celing light conserns me that the roof flashing is leaking near the chimney during wind driven rain.Try a cap it can't hurt & I hope it works.
Sep 30, 2010 | Heating & Cooling
2002 Xterra SE. The sun roof leaks water when it rains. it leaks around the right front corner of the sun roof, above right sun visor on passenger side. I inspected under the sun roof and I did see...
have the rubber seal around your windshield check by a wind shild installer base on what you explain the sel at that corner is leaking and the water is leaking back into the vehicle
Oct 13, 2009 | 2002 Nissan Xterra
Wet ceilings
You must conact your roofer and complain... COMPLAIN.. it sounds like you have a leak and the installers have allowed moistere to get under the roofing materials...!!!
Basically water expands when it freezes (ice cube tray.. over filled ) so if there's any kind of leak the water penetrates.. feezes allowing it to migrate up under the materials and then as the warm air from inside the attic causes the ice to then melt. I'd call and find out what the deal is.. especially if this has been going on SINCE the new roof was installed....
good luck
Oct 26, 2008 | Measuring Tools & Sensors
My chimney is falling down and I want to replace it with a standard galvanized pipe. Is a 6" pipe good enough to run from basement to above roof?
No
the chimney needs to be big enough to carry away combustion products, if the brick chimney has a 10inch square to carry the smoke (100sqin) 28.3sqin for a 6inch round chimney wont do it
needs to withstand combustion heat, mild steel gal wont.
building codes specify what you can use in your region and diameter / house size rules
Selkirk style chimneys sell and are so priced for the reason
Jul 10, 2008 | Heating & Cooling
Selkirk #105082 5"-12" Adjustable Pipe Logo
91 people viewed this question
Top Selkirk Plumbing Experts
Donni Steen
Tom Chichester
Are you a Selkirk Plumbing Expert? Answer questions, earn points and help others
